Old 12-05-2014, 01:46 AM   #1
junksaver
Inner Cowl Removal
I'm in the process of removing the inner cowl and I'm having problems cutting the spot welds along the leading edge by the firewall. I'm using a spot weld cutter, but getting in the channel above the firewall requires tilting the bit at a slight angle due to the drill hitting the cowl and not providing a good cut. If the bit was longer I could get a straight cut because the drill would be above the cowl.
Has anyone else run into this problem or have an easy suggestion on extending the cutting bit?
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 12-05-2014, 06:58 AM   #2
Koffer
Re: Inner Cowl Removal
You need one of these
http://www.google.com/shopping/produ...4&hl=en#sgro=o
Maybe not so long but you can get the idea
'77 P10 (GMs late 60s thru the 70s truck spare parts bin model )
Koffer is offline   Reply With Quote
