Old 12-05-2014, 12:37 PM   #1
j.rigby15r
j.rigby15r's Avatar
drop spring identity
So when I bought my 64 c10 it came with an extra set of front and back coil springs. I was told they were lowering springs. Is there anyway if measuring the springs to see if this is true. If they are lowering and how low I will get? I don't want to put them on and find out they are stock. Any ideas?
j.rigby15r is offline   Reply With Quote
Old 12-05-2014, 03:51 PM   #2
PGSigns
PGSigns's Avatar
Re: drop spring identity
Pictures will help. Also a lot of the drop coils have numbers on them.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-05-2014, 04:03 PM   #3
j.rigby15r
j.rigby15r's Avatar
I can post some pictures here shortly.
Old 12-05-2014, 08:38 PM   #4
j.rigby15r
j.rigby15r's Avatar
Here's some pictures.
Old 12-05-2014, 10:18 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm pretty certain you have stock springs.
When I built one of my trucks a few years ago I snapped these pictures. These are both front springs
The blue spring is 3 inch drop. The silver vein colored spring is 2 inch drop. The blue springs had been run about 1000 miles and taken their set, the silver springs were brand new. After running them a few weeks they took a set and measured exactly 1 inch longer than the 3 inch springs did.
You can trust those numbers as reliable. I personally bought both sets of springs myself brand new.
Old 12-05-2014, 10:25 PM   #6
j.rigby15r
j.rigby15r's Avatar
Are those front springs?
Old 12-05-2014, 10:51 PM   #7
Tx Firefighter
When I built one of my trucks a few years ago I snapped these pictures. These are both front springs .
Correct
Old 12-05-2014, 10:52 PM   #8
j.rigby15r
j.rigby15r's Avatar
Do the back ones seem to be stock?
Old 12-05-2014, 10:56 PM   #9
Tx Firefighter
Very much so. I don't have pictures of lowered rear springs with a tape measure, but a six inch drop spring isn't much taller than your hand from tip of finger to end of palm. Those springs you have there are skyscraper tall in comparison.
Old 12-05-2014, 11:01 PM   #10
j.rigby15r
j.rigby15r's Avatar
Well that sucks. I was hoping I had some drop springs. My truck needs to be dropped something fierce.
Old 12-06-2014, 01:04 PM   #11
j.rigby15r
j.rigby15r's Avatar
So I'm thinking I'm going to try sponge jeep springs in the back and cut 1.5 coils of me extra set and see what happens. I've found some xj springs for $ 20 on cl. I know it kills your ability to haul stuff. But I don't have a bed in it now anyway so why not? Any thoughts?
Old 12-06-2014, 09:34 PM   #12
michael bustamante
michael bustamante's Avatar
If youre not hauling anything why not?
Just be sure and seat your front springs correctly. Notice how they sit in the control arms before you remove them
1967custom
michael bustamante is offline   Reply With Quote
Old 12-06-2014, 09:58 PM   #13
j.rigby15r
j.rigby15r's Avatar
Is their a specific year of jeep or are all TJ'S the same?
Old 12-07-2014, 08:59 AM   #14
67c10rustbuket
67c10rustbuket's Avatar
Those rear coils look way too thin to be truck coils. Have you measured the thickness? Compare to what's on the truck rear already. Those rubber isolators on the rear coils are not from our trucks.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 12-07-2014, 05:49 PM   #15
PGSigns
PGSigns's Avatar
Does not look like truck springs for the front ones either.They do not have the correct wrap for the register in the cross member.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-07-2014, 09:16 PM   #16
j.rigby15r
j.rigby15r's Avatar
Will they still work?
Old 12-08-2014, 05:56 AM   #17
andrewmp6
Not knowing what they are from or the spring rate its a crap shoot if they work or not.
andrewmp6 is offline   Reply With Quote
Old 12-08-2014, 07:29 AM   #18
PGSigns
PGSigns's Avatar
On the front springs I would say no on working. They look to be not big enough around and if you look at Keven's pictures of the truck springs you will see that one end is wound smaller. That is to go around an alignment spigot in the top of the cross member. If the spring is allowed to move around it can hang up on the edge of the pocket in the cross member.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-08-2014, 11:42 AM   #19
j.rigby15r
j.rigby15r's Avatar
I see what you are saying about not having the pigtail on the top. So then if I cut my stock springs I would cut them from the bottom leaving the pigtail at the top?
Old 12-08-2014, 02:53 PM   #20
PGSigns
PGSigns's Avatar
Yes cut them from the bottom. I would do a half wrap at a time. Easy to make them shorter not so easy if you go to far.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-08-2014, 02:57 PM   #21
j.rigby15r
j.rigby15r's Avatar
Jimmy
If I cut them to short cant I put them in a spring stretcher? I have one of those next to my stud and pipe stretchers. LOL
