12-05-2014, 10:38 PM | #1 |
c10 control arms fit a c20?
I have a 72 c20, i would like to update the control arms, spindles etc, maybe even the rotor/bearing assembly as it is heavy.
This is a 2 wheel drive lowered with a 6.0, mainly for weekend cruising/beating
If it ain't smokin' fix it. |
12-05-2014, 10:43 PM | #2 |
Re: c10 control arms fit a c20?
I wanna say yes to the control arms, the spindles and hubs are where my concern is...
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
12-05-2014, 10:54 PM | #3 |
67-72 parts collector,…
C10 uppers will work on a c20 with the correct balljoint installed.
C10 lowers have a smaller balljoint hole than the C20 version.
12-06-2014, 12:13 AM | #4 |
This is true. Ask me how come i have c20 lower control arms for sale.
1967custom |
12-06-2014, 12:25 AM | #5 |
c10 control arms should work if you change to c10 spindles. The ball joints are different
Real trucks have a clutch. Please inform automakers. 1972 GMC, K25, 383 stroker, SM465, NP205, Eaton HO-72 |
12-06-2014, 01:45 AM | #6 |
I don't know if they work, but will post what I know.
My 68 C20 upper A-arm studs were 9/16" The C10 frame I bought has 1/2" studs. All factory stuff. Whether the holes in the A-arms are the same, I don't know. I didn't realize the difference until most everything was thrown away.
'68 C10 SWB '85 K30 Blazer |
01-23-2020, 02:20 PM | #7 |
This is an old one but wondering is the ball joint longer? Not sure why if using C10s control arms, why I would need c20 ball joints. Just curious, my 69 C10 frame is junk. I found a c20 at a good price. The guys says all will work, but has never done it. Can someone give me an answer or point me in the right direction, thanks
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
01-23-2020, 11:20 PM | #8 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Maybe this will help... http://67-72chevytrucks.com/vboard/s...68&postcount=4
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
