![]() Join Date: Oct 2007
WTB 250 Six Cylinder A/C Brackets
I am looking for A/C brackets for 250 6 cylinder. Not sure what is required to be complete...I have a 72 250 with P/S and double pulley crank/Alt/H20 Pump...Is there a 3rd pulley for the A/C on the crank...If so would need that as well?
Thanks, Alan |
Member #1049
Re: WTB 250 Six Cylinder A/C Brackets
Alan, Here are a few pictures for reference to help you get an idea of the brackets needed. (I no longer have these).
Thanks for the pics...That helps a bunch.
![]() Join Date: Oct 2009
There are add-on pulleys to give you the third groove. I can probably come up with a part number for you if it will help. Are you still using the points distributor?
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
Was thinking HEI...Got me wondering now if it is going to create clearance issues? Pulley # would be great but no hurry. Thx.
That bracket won't clear an HEI distributor. Pertronix is an option if you really want to use that type though. The pulley number I have is 329671 AU.
Thanks...
