What To Consider For Disc Brakes On All Corners?
In my build I am planning on running disc brakes on all four corners of my truck. I bought the POL 8 lug disc kit and will be buying the rear axle bracket from (http://www.ruffstuffspecialties.com/...g/EHO5272.html).
What are some of the considerations I will need to have in order to properly run disc on all four corners? Do I need a specific master cylinder? Do I need wider brake lines? Just trying to do some upfront planning for this step. Thanks!
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
Old member
You will need a master cylinder for Disc/Disc and a propotioning valve for the same. Brake lines should be fine other than they will need to add the lines to the calipers. You will need some kind of e-brake also. If you plan to park it any place other than flat surfice.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
