Old 12-06-2014, 11:26 AM   #1
Mjminino
Spindles
Well, as some of you might know I am completely redoing my front and rear suspension. I got the rear all squared away nice and pretty. Get to the front and the damn Spindle wont fit on the lower ball joint! I ordered the correct moog part # so I don't know if maybe the spindles came off a different truck or something. Everything was such rusted crap that I no longer have the old ball joints to compare.
^^^^ Before ^^^^
Turned out to be that PO Frankenstein'd the front end using spindles from a camaro/nova. I found that out by typing in the casting #'s and nothing but those forums came up.
Luckily for me I found some 1971 factory spindles on craigslist for 30 dollars. I got everything all situated and installed but it doesn't look right to me (Then again, I am a complete NOOB when it comes to brakes and suspension). The upper A Arm bump stop is resting on the cross member. Is that supposed to happen with no motor/heavy body panels on the truck? I have nothing to go off of to see if I did something wrong. Hopefully someone can help me. LoL
Mjminino is offline   Reply With Quote
Old 12-06-2014, 05:33 PM   #2
Mjminino
Re: Spindles
Hmm no information, darn
Old 12-06-2014, 06:20 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Spindles
You are fine.
Those springs will compress with weight on the front suspension.
Keith
Convert to disc brakes.
Old 12-07-2014, 01:12 AM   #4
Captainfab
60-66 Nut
Re: Spindles
With virtually no weight on the front suspension, the upper bumpstops will be hard into the crossmember.
Old 12-07-2014, 01:15 AM   #5
Mjminino
Re: Spindles
Thanks guys! You're all awesome!
