12-06-2014, 02:21 PM | #1 |
Cab removal question
so this may be another silly question but for all you guys who have done cab removals at home or on your own. but, when removing the cab with a tractor boom arm, should i leave the doors on and closed for more support? or take them off to shed weight, mind that the cab will just have a 4 inch wide strap and packing blankets for padding on the inside of the roof. im just worried about possibly creasing the roof. then again i may just be over thinking it. any thoughts? thank you
-matt |
12-06-2014, 03:21 PM | #2 |
Re: Cab removal question
I would leave them on if you are moving it that way. When I moved mine it was just a buddy and me. We lifted it off the frame and my wife rolled the chassis from under it.
12-06-2014, 03:53 PM | #3 |
Myself, I would use a different lifting method that doesn't sandwich the cab, doors on or off I wouldn't do it that way. You could make an easy lifting apparatus that goes through the inside of the cab with doors off and lift from that instead. JMO though..
12-06-2014, 04:31 PM | #4 |
Lots of guys use an engine hoist stuck into the cab with doors removed. That's what I did and it worked well. There are several examples on this forum.
12-06-2014, 07:46 PM | #5 |
1961 crewcab
the one cab I lifted with a strap crushed the drip rails, and pretty much destroyed the top.
it was pretty rusty. I would look into somehow lifting it from the cab mounts
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-06-2014, 08:22 PM | #6 |
Check The Champ, Demonstrator
Use a 4X4 with two notches where the weatherstrip glues to around the door frame of the cab.
Remove the doors just to be safe. Make sure everything is detached and the cab is free before attempting lift. 1 stuck bolt can ruin the day. Attach a strap at both ends of the 4X4 the use the boom to lift from the center. then take it to the extreme >>>http://67-72chevytrucks.com/vboard/s...d.php?t=406238
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
12-07-2014, 04:16 AM | #7 |
thank you for all the help. i tried the board in the middle with an engine hoist, i removed the cab from the 65 K20 doner truck like this. it kind of slipped....and the rest is history. so i m not terribly comfortable trying that on a painted finished cab that i put time into. the 4x4 was a heap, plus i couldent sell it so it was disposed of for a case of beer. not my brightest moment.
12-07-2014, 11:39 AM | #8 |
You can't single pick it with one strap unless you use a spreader bar, you will as mentioned destroy the drip rails. A 4X4 towards the front and a belt or chain around each side and lift it.
12-07-2014, 02:26 PM | #9 |
this was my set-up. took it off by myself and put it on my myself. very easy. even had the windshield in when putting it back on. just get it balanced (heaver in the front)
1961 chevy K10 my build is------------61K10 build |
12-07-2014, 02:44 PM | #10 |
Check out the way we did Martin's in his build thread, includes Video of how easy and single handed.
On page 7. http://67-72chevytrucks.com/vboard/s...d.php?t=611614 Video here: https://www.youtube.com/watch?v=Lxcu...lt8TvG8KEwT5Kg Hope that helps.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
