Help with porterbuilt rack heim to spindle
I need help or more info on the heim to spindle connection. There are two misalignment spacers per side and the pics on the instructions are not clear. I drilled out my spindle to 5/8 and the bolt will now pass thru but the question is how to install the funny misalignment spacers. They do not fit inside the spindle. Any suggestions or pics would be very helpful.
Re: Help with porterbuilt rack heim to spindle
The misalignments fit inside the heim. Only the bolt goes through the spindle.
Thanks for the reply, I talked with Nate and I have the wrong heims. These are 5/8 and I need the 3/4 bore.
![]() Join Date: Apr 2005
Why the difference? Are the 3/4 bore for a particular year of spindle?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
The larger bore size is needed so you can use the spacers. The misalignment spacers fit into the 3/4 heim and are needed so that the heim will have freedom to move and not bind up as the suspension moves. You will still you the 5/8 bolt and spindle will have to be drilled out to the recommended 5/8. Hope this helps.
