12-06-2014, 10:37 PM | #1 |
Driveshaft Bearing
Hello all - there is lots of play between my driveshaft and the bearing - seems to be the reason for a slight hesitation when I step on it. Anyone out there replace one of these lately? Any advice appreciated.
12-07-2014, 12:41 AM | #2 |
Re: Driveshaft Bearing
yes its bad, just pull the shaft and put on a new one. a press and bearing separator is really handy. if not cut away the housing and rubber insulator. remove the outer race and then and hammer and large chisel will remove the rest.
12-07-2014, 02:23 AM | #3 |
Be sure to mark both driveshaft sections and reassemble in the same orientation to prevent balance problems.
12-07-2014, 04:12 AM | #4 |
I had a heck of a time getting the old carrier bearing off. I took it to a local driveline shop. He took off the old carrier bearing which was thrashed. He went to press on the new bearing & the shaft that the bearing rode on was cracked. After waiting several days to get the new part which he said had to be ordered out of Southern California, he reinstalled the carrier bearing, I had one really bad u-joint, one that he said was marginal & one that was ok. I just had him replace all three. Between the carrier bearing, new carrier shaft, u joints & balancing the shaft, I was in it over $300. Ouch! It should be good to go for a long while. Hopefully, you can get the carrier bearing off more easily than me & get it replaced. If not, it might be worth checking with a driveline shop if you have one locally.
12-07-2014, 05:43 AM | #5 |
I wonder why the carrier bearing wore so quickly. That one doesn't look too old
12-07-2014, 10:56 AM | #6 |
I was wondering the same thing SK
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
12-07-2014, 07:44 PM | #7 |
Old member
I have a brand new carrier with billet housing still in the box if your interested in it. Never been installed. I'll take $90.00 shipped.
12-07-2014, 07:48 PM | #8 |
thanks but I am going to pass
12-07-2014, 08:12 PM | #9 |
Old member
I just threw it out there no problem.
12-09-2014, 10:41 PM | #10 |
30 years ago I had a 70 c10. I put 3 carrier bearings in it before I polished up and greased the yolk. Then I didnt put another one in.
12-10-2014, 05:26 PM | #11 |
Good advice - thx
12-10-2014, 06:39 PM | #12 |
An out of balanced drive shaft will take these out pretty fast.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
