1966 project
Up for sale is a 66 project I started but do not have time to finish. Run down is front crossmember has been pancaked 1.5", 2.5" drop spindles, 1 round taken off stock could. Control arms were fully rebuilt with new cross shafts, ball joints. I have new tie rod ends both inner and outer with CPP adjusting sleeves. New 5 lug rotors, calipers, hoses and pads on front. Rear has new 5 lug brake drums, new in box moser axles, truck has the first ever gas assisted hood hinges. Body has minor rust in rockers but has a great patina. Engine is a new from what I can tell by the cleanliness of internals and by what I was told by PO. I've put a corvette intake, holley 4 barrel, new aluminum radiator, new water pump and hoses.
What truck needs to be a driver.... Fuel tank, belts, fluids, brake lines for front disc setup, booster master setup and little odds and ends such as wiring hei up. Asking $5000 for complete truck. Title is clean |
| Bookmarks |
