Old 12-07-2014, 08:28 PM   #1
domano 68
Oil appearance question
Changing out leaky valve covers and noticed oil on top of inside of cover is carmel/white colored. Head gasket leak? Oil on dipstick looks clean; seller must have changed oil right before it was sold to me. TIA!
1971 C10 127 in wheelbase
Model Number-CS10934
Body Type & Seating-Fleetside 8 ft.
Original Factory Price-$2,854
Shipping Weight-3,605 lbs
Total Production-206,313
domano 68 is offline   Reply With Quote
Old 12-07-2014, 08:45 PM   #2
BLT gmc
Re: Oil appearance question
?condensation, possibly from dramatic temp. changes and under/non-use. Bruce
BLT gmc is offline   Reply With Quote
Old 12-07-2014, 08:46 PM   #3
domano 68
Cool. Yeah, I believe the prior owner drove only a few hundred miles over past several years he owned it.
Old 12-07-2014, 08:52 PM   #4
BLT gmc
If you feel like it is not running right you could compression test the cylinders and also use a compression tester on the cooling system to check for possible head gasket leaks. If it is running good, I would use it, get it to operating temp for a time and change oil. I bet you will be fine. Bruce
