Old 12-07-2014, 11:41 PM   #1
1980c-10 mybaby
1980c-10 mybaby's Avatar
Age old brake question
Looking for a complete kit to convert to disk brakes on my 1969 burban
rotors(bearings)
spindels
ball joints
calipers
brake booster (and prop valve)
out tie rod
inner
ive come to the conclusion ive done way to much research and im worried ill buy a kit based off price and not whats best for my application(street drive/ tow truck. will get a turbo 4.8lsx in march)
leaing towards willwood kit honestly
any help would be awesome
im leaning towards McGaughys pro 1 kit
1980c-10 mybaby
1980c-10 mybaby is offline   Reply With Quote
Old 12-08-2014, 02:05 AM   #2
jocko
jocko's Avatar
Re: Age old brake question
staying 6 lug? planned wheel type (dia, etc)? This will drive your decision. If stock wheels, then you'll need 71 or newer steelies - 70 and earlier will rub the caliper. If aftermarket wheels, then you're probably fine. Easiest way is to convert to the 71-72 brake system. If you're thinking Wilwood and have a 4.8lsx planned, then I'm gonna go out on a limb and guess aftermarket big wheels? (could be wrong). That opens up all kinds of options for you - including Wilwood.
Personally, I like the POL (Performance OnLine) kits. Complete, good service, etc. CPP carries about anything you could imagine, but I haven't been bowled over by the service. If you want to go 5 lug, most of the above offer rear conversion axles so you can be 5 lug all the way around. I lean toward complete kits when I go the kit route. Personally, unless I'm going slalom racing (which I don't), I think the stock 71/72 front power brake system is more than sufficient for just about any build you can come up with. Beyond that is usually more show than go. Or, well, I guess I mean more show than stop.
Old 12-08-2014, 01:08 PM   #3
Fitz
rotors(bearings)
spindels
ball joints
calipers
out tie rod
inner
Try Early Classic Enterprises. A call to Stan on their tech line will likely help.
Fitz is offline   Reply With Quote
Old 12-08-2014, 01:19 PM   #4
cayce_brunswick-
I bought the early classic enterprise kit last year. Breaks and drop kit with spindles with trac bar and sway bar. I did not have to make a single trip to the parts store. It includes everything and the quality is top notch. I talked to the tech line for 5 minutes just to be sure on a few things. I can not say enough good things about those guys.
cayce_brunswick- is offline   Reply With Quote
Old 12-08-2014, 01:24 PM   #5
Jahloha
Jahloha's Avatar
I bought the POL kit just last month, it all looks great and is complete. Really enjoyed working with them.
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
