Old 12-08-2014, 05:26 PM   #1
ryanmctee
ryanmctee's Avatar
Firewall Junction Box
Does anybody know where these green fusible links from this junction box go? The PO has really hacked the wiring in this truck. 1976 GMC K1500. Thanks in advance - Ryan
Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=512620
ryanmctee is offline   Reply With Quote
Old 12-08-2014, 05:55 PM   #2
77K10Silverado
77K10Silverado's Avatar
Re: Firewall Junction Box
You know mine had/has some like that. One was cut short like yours and the other to a brake controller. I'd say they are aftermarket? I just took off the cut one and trashed it..
77K10Silverado is offline   Reply With Quote
Old 12-08-2014, 05:56 PM   #3
ray_mcavoy
Those two fuse holders do not appear to be factory equipment. They probably went to some aftermarket accessories that the PO removed.
ray_mcavoy is offline   Reply With Quote
Old 12-08-2014, 06:00 PM   #4
ryanmctee
ryanmctee's Avatar
I'm kinda thinking that same thing. The PO has done some pretty 'custom' stuff to this truck. Thanks for the replies. - Ryan
Old 12-08-2014, 06:08 PM   #5
gmachinz
Those are aftermarket inline fuses.
gmachinz is offline   Reply With Quote
Old 12-08-2014, 06:08 PM   #6
Just call me Sean
Just call me Sean's Avatar
They're not fusible links, just fuse holders. I have to agree, they aren't factory. Never seen the factory use green on the junction block, and they certainly don't use fuse holders.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 12-08-2014, 06:23 PM   #7
ryanmctee
ryanmctee's Avatar
OK, so then should there be anything coming off this block? If not, then why is there in the first place?
Old 12-08-2014, 06:51 PM   #8
ray_mcavoy
On most trucks it's just the two red wires you can see off to the right in your pic that tie together at that junction.
But it serves as a power distribution point for factory options such as air conditioning, aux battery, HD trailer wiring, and such. And it also makes a convenient power distribution point for aftermarket accessories.
Old 12-08-2014, 06:52 PM   #9
ryanmctee
ryanmctee's Avatar
Thank you Ray. I'll lose the green wires and keep it in mind for any future accessories if any.
Ryan
