Old 12-08-2014, 08:40 PM   #1
pontiac6269
pontiac6269's Avatar
Transmission Yolk ?
How much the yolk should be sticking out at the transmission? Would the amount sticking out be the same as my 85 K5 4x4? Do these take a longer yolk then a car would, have yolk out of a turbo 350 that was in a car. Truck is a 81 C20 that I swapped in a 700R4. Switching to a one piece drive shaft. Rear is a corporate 14 bolt full floater. My truck had a turbo 400 with a two piece shaft. I don't want to cut the shaft just in case the 700R4 doesn't work out.
Thanks,
Eric
Eric
2001 Ford F350 EC dually 7.3
1981 Chevy C20 to K20 350
1978 Oldsmobile Cutlass Supreme 455 Pontiac
1969 Pontiac GTO 400
pontiac6269 is offline   Reply With Quote
Old 12-09-2014, 08:56 AM   #2
xrcr
Re: Transmission Yolk ?
http://www.maliburacing.com/auto_tranny_id.htm This has good info on lengths. I put a 350 where a 4spd was went to single drive shaft I used a 350 yolk. iirc have an 1" +/- in the tailshaft
xrcr is offline   Reply With Quote
