![]() Join Date: Sep 2013
Big hump little hump question
I have a 69 truck with a little hump with a 3 speed manual. I also have a parts truck with a big hump, th400 and a 396. Question: will the trans and 396 fit the little hump truck?
1969 Chevy Stepside |
Re: Big hump little hump question
I dont think it will. However, converting the small hump floor by using the large hump (bolt in), takes an hour or two depending on the tools you have. It's fairly common conversion.
///Relaxed Atmosphere |
I've heard of lots of folks on here that have done big blocks with T400 and used little humps. I like the high humps myself. One of my three already had it being it was a 396 T400 truck and the other two I already have a high hump for each of them again just cause I like the look.
![]() Join Date: Mar 2003
Yes, as long as the body mounts are not the original you can get your hand around the top of the 400. It's not that tight.
i did it no problem
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
Thanks for the info... However does one of you have a BB in a small hump cab? I only ask that because I plan on pulling the 396 and start the overhaul yet I have an option to trade for a SB already overhauled. I am stuck until I know for sure.
yes a big block with a the 400 trany in a low hump floor fits like it was meant to be there. mine started out as a in line 6
All about them K’s
![]() Join Date: Jun 2014
That sure is Purdy!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Wow, OK I am inspired again.
