12-09-2014, 03:23 AM | #1 |
Wheels will these bolt up
Looking at these for the summer...thanks in advance.
(20x9) Wheel Size 20x9 +37 Bolt Pattern 5x5 or also labeled as 5x127 71.5 MM Hub Bore 84 swb
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
12-09-2014, 12:10 PM | #2 |
Re: Wheels will these bolt up
Those are the Jeep Grand Cherokee SRT wheels. They can bolt up but you will need spacers to make them work. If I feel up to it, I can try one of them on my '87. Can't promise anything.
12-09-2014, 12:15 PM | #3 |
12-09-2014, 12:20 PM | #4 |
they almost look like irocs they woulda looked nice on it
12-09-2014, 02:45 PM | #5 |
Just got finished trying these out so here is what I found out. The front you will need an inch spacer to work. The rear will need at least an inch spacer to clear the tire from the inside wheel well. An inch and a half or even a two inch would be better so the tire can be closer to the outside. Here are pics of the wheels on my '87. Keep in mind that the wheels are 10" wide and tires are 295/45/20s. Sorry, couldn't lower the front body down. Ran out of jacks and jackstands. At least you'll get the idea.
12-09-2014, 02:46 PM | #6 |
12-09-2014, 02:48 PM | #7 |
12-09-2014, 06:02 PM | #8 |
^thank you so much! Both of those wheels look great on the square the first do look like irocs. Are spacers safe?
12-09-2014, 07:12 PM | #9 |
Don't know about safe but I know people use them on their cars and trucks. Maybe someone with more knowledge about these can chime in.
12-09-2014, 07:30 PM | #10 |
I entered in 'wheel offset conversion' & selected one of the first five listings to find this in just a few seconds: A 9" wheel w/+37 offset = 6.45" back spacing. For perspective, a 15x8" truck ralley w/4" back spacing = -12mm offset. http://www.mrw-wheels.com/wheel%20te...t%20chart.html Scroll down the page a little.....
12-10-2014, 03:29 AM | #11 |
I would find different wheels not a fan of running spacers seen a few fail its never pretty when it happens.
12-10-2014, 11:18 AM | #12 |
There's a difference between "spacers" & billet "adapters" as far as safety. A billet adapter would be needed in this case & would work.
12-11-2014, 02:58 AM | #13 |
What's the cost of the billet adapters tho?
12-11-2014, 10:13 AM | #14 |
Around $50+ each depending on thickness/complexity.
