Should I "Z" the front? Opinions please.
Long time lurker who finally joined. I've been following lots of builds here. There doesn't seem to be a huge number of Z-ed trucks or maybe I'm missing them.
I'd like opinions from the experts I see on here please. I don't mind fab work at all, and to me it looks like a 2"-2.5" Z is an easy way to get that extra 2+ inches. I know the steering has to be reworked, but there'd be no need to pancaking the crossmember, right? I'm looking to get somewhere close to laying frame. Just got my step notch kit in the mail for the rear, but I'm undecided on the front. Going to do the rear notch then start up front with cupping the LCA's. Here's a pic to see where I'm at so far. I basically have a "blank canvas" to work with now. Thanks |
![]() Join Date: Jan 2011
Re: Should I "Z" the front? Opinions please.
With air and drop spindles and a tire about the size of yours mine will drop the front till the cross member just misses landing on the ground. The back with the rear end resting on the bottom of the bed is the limiting factor of it going any lower aired out. You may want to pop the springs out of it and set it down and see where it lands. That will give you an idea of how far you need to go. Got the cut the bump stops off the lower control arms to let the front down.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Mar 2005
Are you looking to Z the chassis for the benefit of maximum drop or just to gain extra ground clearance at ride height?
We Z'd my '64 2 inches, and while it was apart, moved the section 1" forward to center the front wheels in the fender openings. Z'ing the chassis is a cheap way to gain ground clearance, which is a critical commodity on our trucks when they get lowered. If you lower the truck more than 5" in the front, the lower control arm clearance to the ground becomes a major concern, and over time, you'll beat them up. There are threads on the site showing how guys made their cuts, and the common way is to make your rear cuts at an angle, so when you raise the crossmember up, you're bringing the wheelbase forward at the same time. The actual cutting and boxing is relatively simple, and the cost is basically whatever the material is for the boxing plates at the frame splices. To make things as simple as possible, just ensure that your cuts are made behind the core support and aft of the upper shock mounts. You MUST keep your core support in the stock location, and you need to ensure that the shock points move up together with the Z. You want the steering box, crossmember, and shock points to ALL move up together as one unit. The harder work (more tedious) comes with everything that is affected by the Z, like the steering column linkage, brake lines, trimming the inner fenders, re-drilling the position of the drag link, and motor and trans mounts. For the column linkage, you will need to cut your shaft and add a u-joint, and if you go 2" or higher on the Z, you will need to clearance the driver's side upper control arm because the shaft will hit at full compression of the suspension. Brake lines can be either be spliced or completely redone (recommended). The inner fenders will need to have the lower edges trimmed because the framerails will now be higher. The drag link mount of the passenger side will need to be repositioned, which is a simple drilling of a new hole in the bracket. The motor and trans mounts are up to the option of the installer. You can leave the engine mounts in the original location on the crossmember, but you'll have to trim the transmission cover in the floor if you have a low hump. If you have a high hump floor, you'll be OK. The trans mount will have to be shimmed or you'll have to make a new mount to keep the engine/trans at the right angle. Also, keep in mind that you should always recheck the entire driveline angle from the transmission all the way back to the rear end after any major mod like this. Oftentimes, you will have to shim or reposition the carrier bearing to keep the driveline angles correct. If you like to fabricate, and you want to do stuff for less cash, Z'ing is a great way to go. Just be prepared to do a lot of the little details to make it all work properly.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#4 | ||
And yea, I actually do enjoy the fabricating part. Thanks guys! |
I Z'd 75 but am not completely back together. It was a fair amount of work but it was pretty fun doing it.
My 66 has a sectioned crossmember (2''). Honestly it looks like just as much work (I didn't do it). The motor was moved up and forward, the steering was raised, the steering shaft had a heim joint added. I prefer a Z because it buys you more drop with a similar amount of work. FYI on my 66 they lowered the body mounts an inch to get an inch more drop. Might be an option for you if you want.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
its just $$$$$
Its not a 60-66, but I Z'ed my blazer 2.5" and cupped the lower arms. Its definitely a cost effective way to get your truck low if its done correctly. measure,measure,measure.......
Damn. Nice blazer.
its just $$$$$
Nice Blazer!
Did you use the stock upper control arms? I'm just wondering about camber. I assume with the longer tubular uppers you can't z because of the steering shaft. |
its just $$$$$
#11 | |
I did 7/8" and it ended up being a hair too much and I had to shorten my uppers a bit to get rid of my positive camber.
its just $$$$$
