What's involved to install rear sway bar?
I'm interested in gaining little more stability in my 72 k10. I see dorman offers a sway bar for $100. What kind of project would this be to install on my rear 12 bolt?
Re: What's involved to install rear sway bar?
I went with a CPP rear bar I bought from another board member. That one requires drilling two holes (one per side) into the frame and two holes per trailing arm. Ratcheting tie down straps help a lot when mounting to the trailing arms. Not extremely hard to do. Be aware it will make your truck ride rougher as it limits travel of the trailing arms.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
20' Daredevil (Ret)
![]() Join Date: May 2003
With a K10 he has leaf springs so no trailing arms. Should be basically a bolt-on, but you may need to drill holes in the frame for the end-links. See if you can get the installation instructions, they'll give you the details.
Sorry, I missed the K10 part.
20' Daredevil (Ret)
It's all good.
![]() Should mention this to the OP -- do you already have a front sway bar? If not, install one before adding a rear bar. Rear bar only, with no front bar, can lead to some strange handling characteristics.
