Valve cover restoration?
Any suggestions or proven methods..Before n after pic's always welcome.
Here is what I would be starting with.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Re: Valve cover restoration?
Acid dip and a polish would be my first thoughts. Are they steel or alum? And then could paint between the ridges.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
I have the exact same cover, they are good quality, made in Japan for MT. I will watch for suggestions on polishing
71 C-20 07 Magnum RT AWD |
No steel here. Use steel wool first or not?
![]() Join Date: Nov 2013
I just saw a set on the Challenger board and he had them powder coated. Looked sharp
I have not seen these covers on a small block since back in the 70's, MT was an American Hero ! He set the bar real high at Bonneville , Drag's and even Indy. Looking forward to getting mine installed soon. How can you polish them with those deep groves in them ?
I would sand them with 400 grit and work up to 3000 grit. Then polish them.
71 K20 64 GMC mud truck |
![]() Join Date: Feb 2012
Have them glass beaded, paint with hi-temp wrinkle finish paint the block sand the fins so they go back to aluminum.
Mothers aluminum polish and a polishing ball or cone. You could hit them with 400 or 600 before polish. I had a set of wheels that looked worse and they came out great.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#10 | |
Cluster King
![]() Join Date: Nov 2012
I am going to do a set as well soon. I plan to leave the area between the fins glass beaded finish and polish the high fins and the sides. I will post photos when they are done but it may be a while. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
