Old 08-19-2003, 10:04 AM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Bushings for rear leaf spring eyes on 72
I have about decided no one has urethane bushings for rear leaf spring eyes for a 72. I have found the metal encased rubber which I guess is the way I will go.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 08-19-2003, 10:44 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Try your local spring shop. Mine charges 6 dollars per bushing, and that includes removing the old one and pressing in the new one.
Old 08-19-2003, 01:05 PM   #3
mocwon
Keep On Truckin'
mocwon's Avatar
Is $6 for the rubber encased in steel or did you find urethane? Thanks, Greg
Just Passin' Thru
Old 08-19-2003, 01:08 PM   #4
Tx Firefighter
plain old rubber
Old 08-19-2003, 04:44 PM   #5
mocwon
Keep On Truckin'
mocwon's Avatar
You are right......... I can get the rubber steel encased stock type for $8.16 each installed at the local spring shop. Thanks for the lead.
Just Passin' Thru
