Old 12-09-2014, 05:05 PM   #1
slotard
Steering column swap
I have a '73 C20, 350/350 column shift, no tilt. The ignition linkage is giving me a lot of trouble, I can't manage to get it working right.
How involved is swapping for a tilt column? I figure if I swap for something else I might as well improve it.
Thanks for any advice.
slotard is offline   Reply With Quote
Old 12-09-2014, 05:13 PM   #2
NJ C10 Guy
Re: Steering column swap
Its pretty easy, just a few bolts and screws and you're set. I just did one, but I swapped out the ignition cylinder and ran into a small problem that was easily fixed, just had to take it back apart. If you arent swapping out the ignition cylinder or the steering wheel, it's a piece of cake. Just make sure you get the correct year column that will bolt up to the intermediate shaft. There are plenty of writeups on how to do it.
NJ C10 Guy is offline   Reply With Quote
Old 12-09-2014, 05:19 PM   #3
slotard
So I need to find 73-78?
What was the problem you ran into?
Old 12-09-2014, 05:47 PM   #4
NJ C10 Guy
Yes, there are 2 different shafts, I believe yours will be a spline shaft. My key wouldn't turn, which I didn't check before I buttoned everything up. There was a piece that was binding it. Easy fix, but a pain because I had to take it apart again.
Old 12-09-2014, 06:34 PM   #5
slotard
What was binding it? My current symptom is that, even with the small leaf spring in that applies some load to the rack & pinion made up of the cylinder and ignition actuator, I jump teeth before it pushes the rod. Right now I have some parts removed and am just pushing on the rod to start it, but it takes a lot of force.
Old 12-09-2014, 07:00 PM   #6
NJ C10 Guy
It was the contact for the warning buzzer, which is directly beneath the ignition cylinder.
Old 12-09-2014, 07:19 PM   #7
slotard
Oh, you have a tilt column. I don't think my truck has a warning buzzer anyway.
