12-09-2014, 08:44 PM | #1 |
Short in wiper switch or dash?
So this is a weird one...
Was going to take the truck out for a drive today and when I turned on the wiper switch, rather than turning on the wipers, it illuminated the right turn signal indicator on the dash. What!? I assume there is a short somewhere - but I wonder the best place to start looking is. I pulled the steering wheel and looked as best I could at the components in the column, couldn't find anything that looked suspicious there. I tried playing with some other controls to see what else might be going on, and I found another weird one - when I turn the dash dimmer switch all the way to the left - just before it turns on the cab light - it also illuminates that right turn signal indicator. For what it's worth, when the turn signal indicator light is on and I turn on the right signal, the flasher does override it and cause the indicator to flash as normal. I'm completely lost - I'm thinking maybe I have to pull the dash and check for a short back there? I've looked from underneath, can't see much - all of the connections appear to be solid, but I can't really tell what's related. Any thoughts?
'84 K20 350/465/208 |
