Old 12-10-2014, 10:35 AM   #1
clemsonteg
air tank inside the cab
I'm trying to find a place to mount my air tank and I only have two options. I am trying to fit it between the cab mounts on the passenger side. It will be lose, but it may work. If that doesn't work, I'm thinking of putting it behind the seat where the tank used to be. Should I be concerned about a 200 psi tank directly behind my seat if I go that route? I have a 200 psi switch and a 250 psi safety valve.
clemsonteg is offline   Reply With Quote
Old 12-10-2014, 04:08 PM   #2
catch2otwo
Re: air tank inside the cab
Chances are nothing will ever happen and it will be fine. But I'd hate to be in the cab if anything ever failed
catch2otwo is offline   Reply With Quote
Old 12-10-2014, 05:18 PM   #3
lower50's
lower50's's Avatar
under the box just behind the cab? That's prob where I'm putting mine
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
