1968 no a/c heater fan low-med-high slide bar location
Searched forums and internet, what I'm looking for is where the fan slide bar location should be on the different speeds? Mine are all the way to the right and very close between speeds where it's hard to adjust, with high as far to right it can go. Most times it does not stay in high and slips back to a lower speed. Is there an adjustment for this? They all work, just have to slide what I think is to far over to right to work.
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
Re: 1968 no a/c heater fan low-med-high slide bar location
I have the same issue too, I'm watching for answers too.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
ttt
Mine is or was too, and I have to say as far as I remember that's where they were back in the day, It worked but wasn't centered well with the switch. Mine at the moment is just a toggle switch. off on due to having put a couple flimsy aftermarket control cables on my truck and the wire bends up at the box lever. I'm thinking about modifying a lawnmower control line or maybe something off a tiller, they seem to be heaver than the one's I've picked up aftermarket. Now back to the subject I remember LOW at the left end of the switch Med was roughly in the middle or just after middle of the switch and HI was at the end of the slide switch. I think from the factory MED and HI were really close to each other no matter where that falls on your slide switch.
Is there an adjustment with the actual Heater Switch that the control arm connects to? Assuming that heater switch actually controls the speeds? My cable I bought new have only one area to secure to clamp which is not adjustable.
