Moderator
![]() Join Date: May 2007
Manual choke on a 68?
My 68 originally had a manual choke. When I bought the truck, it was disconnected and coiled up behind the dash. I would like to use it again, as the carb currently has a divorced choke and I want to eliminate it. The carb is a q-jet but I'm sure it is not the original. Does anyone have pictures of how it is set up? I have no idea where the cable is supposed to exit the firewall, and I assume there is some sort of bracket or brackets required to connect it to the carb? Thanks!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: Manual choke on a 68?
mine was a six with a manual choke hope a pic can help
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
and I found a pic of where it came out of the fire wall its the top gromit that is by the electical fuse box
Moderator
Thanks for the pics, I guess I should mention it is a V8 and I think the cable attaches to the opposite side of the carb.
Moderator
Here is what I currently have.
What's wrong with the choke you have?
Moderator
It does not function and I want to put the manual cable back on.
All the choke parts appear to be there. Easier to fix what you've already got.
What doesn't it do? Since there weren't any manual choke quadrajets, you'll need to mickey mouse up some brackets to make it work. |
