12-10-2014, 07:58 PM | #1 |
Stock LS1/4L60E Swap
I also have a complete LS1/4L60E out of a 2001 Trans Am.
If the built one below sells, I'll keep this one or v/v. Motor is mostly stock - has new lifter trays, GM lifters and LS9 valve springs. Trans is a fresh rebuild with zero miles. Comes with PCM, harness, F-body accessories and oil pan. This one is 2,900+shipping from central Iowa or I can meet in the general area.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
12-13-2014, 01:46 AM | #2 | |
The Older Generation
Re: Stock LS1/4L60E Swap
Not knowing too much about the newer engines I presume this is a 350. Will this fit in a '67 pickup without too much trouble? Mainly I am wondering about the oil pan and stuff since it came out of a car. How hard would it be to integrate the LS wiring with the '67's loom? Would I have to buy one of the aftermarket looms? Thanks, LockDoc
12-13-2014, 10:40 AM | #3 |
Leon,
It's an aluminum 346/5.7. Yes, f-body pans will fit in easily, you'll need a set of trailblazer ss headers or manifolds. The engine harness will need modified - there are a lot of unnecessary wires that are removed and fuses are added for various things - o2 sensor heaters, fans, a/c, cpm, etc...you can have that done for anywhere from $2-300, get a set of $40 adapter plates off of ebay then it is a very simple installation.
12-13-2014, 11:20 AM | #4 | |
OK, thanks for the info. I will do some thinking on it.... LockDoc
12-14-2014, 01:46 PM | #5 |
I will take this engine/ trans combo Jon. Thanks, LockDoc
12-14-2014, 08:07 PM | #6 |
Super, nice talking to you today Leon! See you next weekend hopefully.
