Where to find a certain dash part??
A few months ago I bought a 1978 GMC 4x4. The shift indicator was missing, so I bought a new one from LMC (with some other dash parts too). Upon removing most of the dash parts, I noticed that the bottom right tab of the dash cluster housing was broken off. This is the part that the indicator wire linkage runs through. Well I can't seem to find where to buy this darn part anywhere, except on Ebay where you have to buy the whole cluster for a small fortune. Does anyone know of a place that sells this part as a new replacement?
Example pic (found searching in this forum) of the part below: ![]() |
Re: Where to find a certain dash part??
I think you are refering to the housing being damaged somehow. You might be able to use a little fiberglass filler (gorilla hair mesh with the epoxy) and form a slight clump. Then go back in with a drill or chissel or grinder and cut back to form the part to make it work. this method could also be used for broken tabs on the instrument cluster, etc too.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
Yes I am looking for a whole new plastic housing as the ones posted in the pic. I can't seem to find these as a reproduction part anywhere. Only old ones on Ebay that come with the whole dash cluster, and usually way too high priced.
Unfortunately, I don't think anyone is reproducing the plastic cluster housings.
Repairing your existing one like Jeff said is probably your best option. Although that lower/right tab where the shift indicator cable goes through would probably be difficult to re-create. So cutting that section from a junk cluster housing and gluing it onto yours would probably be the easiest fix. The warning light style clusters make good donors for this type of thing because they're usually cheaper than the more desirable gauge clusters but all of the outer tabs are the same. It'll probably be cheaper/easier to find a junk housing at a salvage yard instead of ebay. In fact, the reference pic you used is of a 77 tach cluster housing that I repaired a while back. The far left mounting tab was missing so I cut one from a junk cluster and glued it into place with some Permatex "Plastic Weld" epoxy. Then I freshened it up with some white Krylon Fusion plastic paint. |
Yeah I read that thread and that's where I got your pics. That thread came up on Google when I did a "1978 GMC dash housing" search. When I saw that pic, i was hoping that the one at the bottom was new! You did a good job on that one. It looks like I'm gonna have to rig something up in order for my shift indicator to work. It's crazy that out of all the parts you can find from LMC and Classic Industries there isn't a replacement for this one. At LMC, it looks like they literally have EVERY part for the dash, except that one. They even have the little foam gaskets for the blinkers and small info/warning lights!
ive got one or 2 or 10 of them you need one with a electric oil pressure? big fuel gauge
My dash has the large fuel gauge on the right, speedo in the center, and only the 4 idiot lights (no gauges) on the left half of the cluster. PM me if you have one you can sell! Thanks
Just keep in mind that any cluster of this age "can" be brittle. So be cautious and don't get too upset if something snaps off easily. Still say....fiberglass body repair is worth a shot with nothing to lose.
Also, one thing to do before re-installing.....spray the inside of the cluster with chrome paint. This will really help brighten up your gauges at night with the standard bulbs.
heres the pics
more
Yep, that's the same as my dash. The bottom right tab with the parking indicator wire channel is what is missing from my housing. That would be awful hard to replicate with fiberglass filler...
78K & 79C Jimmys
I found somebody screwed a wheel into that hole in my 79,works fine.
but not if it's all gone
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 12-18-2014 at 10:46 AM. |
