12-11-2014, 12:06 PM | #1 |
Power steering with LS motor
I'm doing an LS motor swap into my 71 gmc (originally 6 cylinder, auto truck) and looking to switch from manual to power steering in the process.
For background, the motor is an '02 4.8 and will be running a carb set-up. I'm using the new CPP sheetmetal ls motor mounts. Any idea the best way to go about this? I looked at CPP and they have a conversion kit but it's $699. Is there a more cost-effective kit or way to do it? Thanks in advance for the input and advice.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
12-11-2014, 12:40 PM | #2 |
Re: Power steering with LS motor
In my 68 I used a power box from a 78 c10 , and the pump that came with the 08 ly6 6.0 that is under the hood
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
12-11-2014, 01:11 PM | #3 |
FYI, I currently have a 78 C10 power steering box with my 2005 Vortec 5.3 power steering pump. I'm on my second NAPA made up, leaking, dripping power steering hose. I'm going with the following solution SOON. Contact Pat at Benchworks in Scottsdale Arizona. They have done lots of our 67-72 Trucks with Vortec Engines and have The Best set-up all figured out. They have a later 80s Power Steering Gear Box (Best Ratio) that also uses the late model GM Metric 16 MM o ring (2006 Vortec V8 pump) to 12 MM O ring (steering box) pressure line and the new generation rag joint required. They can UPS you all that stuff at way better prices and in my experiences with them, probably better quality than what you've been talking about here
Bottom line if you ever need a replacement power steering pressure hose in the future, walk into any auto-parts store and get an OEM replacement, no jury-rigging multiple hoses and fittings that can leak. Just a thought
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" Last edited by Lees68GMC; 12-11-2014 at 01:20 PM. |
12-11-2014, 02:05 PM | #4 |
Not exactly sure what the question is. You would do a power steering swap with the gear and linkage just as if it had a 350 (or whatever). You would use the LS power steering pump and reservoir. Run a return line from the gear to the reservoir. If the return hose is not long enough, add on with a nipple or replace the hose part with a longer one from a hydraulic shop. On the pressure hose you can buy custom ones, but the easiest way is to add a JIC fitting in the middle and splice together there. Take the original hose and route towards the pump; then the hose from the pump towards the gear. Cut both in the middle where they intersect. Have a JIC (or sometimes called a "bullnose") fitting installed in both-male in 1 and female in the other. Connect and cover with loom and you are set. JIC fittings are available for all common hose sizes. This also gives you the ability to turn the hose how you like it before connecting in the middle so you don't have to be exact as when you made one.
Just curious-why carb an LS? The cost of carb vs: computer is not that much savings and you still have to run an electric fuel pump.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
12-11-2014, 03:57 PM | #5 | |||
And I'm going carb bc I got a good deal on a motor with some of the carb set-up already, didn't want to fool with wiring, and i like the look of it. I feel it keeps a little bit of the old school feel under the hood. I'm planning to cover the coils some sort of valve cover set-up.
12-13-2014, 12:59 AM | #6 |
In my 72 K10 (factory p/s with an LM7 swap), I simply ran the pump that came with the LS engine, a new-but-same as original RedHead steering box, and some NAPA-made lines between the two. 5000 miles on it so far and no leakage issues...
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
12-13-2014, 11:15 PM | #7 |
Very helpful. Thanks!
12-14-2014, 02:37 AM | #8 |
In my 68 with 5.3, I ran the stock power steering box with stock hoses, and the stock 5.3 power steering pump. It required an adapter to adapt the 68 hose to the 2005 5.3 pump, which I got at NAPA. Can buy hoses at any parts store. In my opinion, cheapest way to go. You might not like the feel of it, because it's way easy steering. You can also change out the pressure valve fitting in the pump to the 68 fitting, which will make the steering less "power". Good luck, you'll love your LS powered truck. Jim
12-14-2014, 02:57 AM | #9 |
