Old 12-11-2014, 02:21 PM   #1
c20pickup
Question about brakes for a disc c20
I am converting my 70 c20 to four wheel discs, using a 71 front end and a newer aam1150 for a rear axle.. My question is, what master cylinder do i need to go with? Also a brake booster, will my stock booster work with a different master cylinder. Or do i use my factory master and boosyer and run a proportioning valve? Need some help here, this is a 3/4 ton so does bore size change on the master? Want something to bolt in without cutting and still use a vacuum booster
c20pickup is offline   Reply With Quote
Old 12-12-2014, 02:06 PM   #2
c20pickup
Re: Question about brakes for a disc c20
Anybody?
Old 12-12-2014, 04:40 PM   #3
john
member #16
john's Avatar
Since no one has replied, here is some posts to look through.
http://www.google.com/custom?domains...D%3A1%3B&hl=en
john is offline   Reply With Quote
