Doing a 52"/56" swap, Q's left after a year of research and contemplation.(noob here)
I've read everything on the web twice, watched the vid's. Going for a rig that can haul gear, and a quad or two (in bed) as far as the trail is wide, and still haul horse food. (thats not necessary, just a small future possibilty, it can always be delivered). My packs are 6 and 8 leaf so I'm not concerned too much with softness, and good shocks should help with that. I've got my plan except a few things like:
home made weld on brackets, pre made weld on ones or bolt on for shackle hangers and the like. weld on I've read leaves a small window for error on the welds, bolt on not so much. Best route? cut and mount new multi-hole axle perches where necessary vs. shim the axle and ez-inch. is there a better choice for a dual purpose rig? where are greasable bolts/bushings REALLY effective and should be implemented? Cross over or stock steering? hydro assist? I've heard the two sides and bump steer sneaks into both scenarios. Cross over seems to be the route but I've read where stock has been modified effectively. with 37's does the d44 need trussed or would reinforced C's cut it? (trails hard if needed, not racing or jumping) Flange vs CV vs double cardan vs U joint on the driveshafts? (I might have repeated the same thing with a different name there, excuse my noobness) and with new shafts, is a tranny/transfer drop necessary? haven't read about it yet, but i know it can surface unexpectedly. would clocking the transfer be something to think about at this point as well? Experience, theories, ideas, all welcome and thanks in advance. Would really like to get the "personal opinion" narrowed down to a pin point. |
Re: Doing a 52"/56" swap, Q's left after a year of research and contemplation.(noob h
If you want to run 37s i would skip the dana 44 for a dana 60.37s are the limit a dana 44 can handle with a ton of upgrades even then you can still break stuff.What brackets to run are up to you im lazy i would go bolt on.Steering cross over would be better off road then the stock set up.Hydro assist or not is up to you but if your gonna ride hard trails/rock crawling i would use it.
a 60 will have to wait, they want 1000-1500 for one around here so it sounds like trussing and reinforcing the C's is the option. thanks for the input!
Have a dana 60 and dana 70 rear I'll make you a good deal on and I'm local
#5 | |
But a truss and plated c won't stop you from breaking the ears off the stub shafts or busting u joints left and right.If you want a dana 60 cheaper find someone that parts out the cucv military trucks they used a dana 60 front.Or a dodge dana 60 will fit with these http://offroaddesign.com/catalog/Dod...apBushings.htm
37s are fine for a Dana 44. 60s are overrated and hydro assist kicks ass, but not necessary. Crossover does excellent for my truck. 4" lift.
Tuff country 4" front springs handle better on road and flex very well off road as well. A shackle flip for the rear and stock 52s do really well, 56s see no major gain other than load capacity. I kept breaking front cv shafts so now I am running a single 1350 superflex joint at pinion and tcase. I have all my cases clocked flat. Stock is fine. It's wheelbase dependant. |
#8 | |
I have a BBC and the tc springs did sag a bit. That may contribute to my firmness, but I'm satisfied with how they handle with thick 56s in the rear.
the whole dana 60 vs d44 argument is forever ongoing. i like my 60s. i have never broken one. i have done A LOT of repair work on 44s in the past and never on housings or c's. its always diff gears, R&P, stubs or axle joints. locking hubs have been an issue as well. this is all on trucks with 35s or smaller. there are a lot of parts in the aftermarket that make all of this less of an issue, but by the time you add them all up i would rather chase down a 60. as it is, nothing i own doesn't have a 60. i would run a 44 with 37s, but i would be doing so knowing that with my "release the 454 powa" attitude to obstacles it would be something to repair.
Thanks everyone!. great info here, D60 will be justified when the 44 breaks, I'm running a 292 pushed out to a 312 or something like that, We'll see if the torque is enough to break it.
Panhard bar and hydro assist seem like the most important things to add ATM. So far the roughest I can think I'd want to push it is a trail I managed with 33's, but I've had the steering lock up in flex ( snapped a front leaf, replace with sdtrucksprings.com spring and just two months ago i realized this lock was from having only a half inch of clearance from the tie rod... another push for 52's), had a 'V' between boulders and came within a half inch of the frame. Now of course there's the "watch this" and "let's see" occasions and the wheelinbug always wants you to go further. and the times when things change, trees fall, rocks slide, mudhole is deeper than expected when the next step up in upgrades would have made for piece of mind or avoided the break. BooneDogs72: thanks for the offer, but I'm pretty happy with what I've got planned and have already detroit locked eaton ho72, "hd", if you still got them in a while when either the bug makes me itch or when i break something, I'll be PM'ing you. |
#12 | |
#13 |
Post pics of the 292. Stat.
#14 |
Its not the engines power its the weight of the wheel getting jammed up that's when you break stuff.I have seen jeeps running the stock 4.0 and 37s break a gm dana 44 in the rocks.
#15 |
PO built it, i got the truck with 20k on the 6.
And as soon as I get it back I'll take some good pics for you guys, of the engine for obijuan, and the truck as I need to get them on here anyways. Thanks for the advise andrewwmp6. |
#16 |
is it required to pay to post pics? I follwed the FAQ page about how to post and it says the admin have not allowed me to. Sorry everyone
#17 |
Use photobucket and use the URL link pasted here.
#18 |
No any member can post pics. I have a hard time because they are so big but cropping helped out A LOT.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
#19 |
Well I signed up for photobucket to help with the cropping and whatnot, finally got some good weather and I'll get some pics up on Monday.
| Bookmarks |
