Old 12-11-2014, 03:58 PM   #1
70shtbx
Modern camper on classic 1 ton chassis ?
Have a '70 c30 w.Franklin motorhome about 9 years ago. been looking at more modern motorhomes as I near reirement. Like the classics, have a '71 c10, but would like the more amenities of a more modern camper. Toying w/the thought of removing the Franklin and having a newer camper/cab over installed. Have not been able to find any pics. Would be nice to have the, on the road capability to fix most anything that could happen w/ the classic engine/truck design but have the modern amenities that a newer camper could afford.
Doesn't seem like it would be that hard, even if I couldn't use the pass thru and had to go w/a box design, I think it would be cool.
Thoughts.
70shtbx is offline   Reply With Quote
Old 12-11-2014, 08:01 PM   #2
yuccales
yuccales's Avatar
Re: Modern camper on classic 1 ton chassis ?
That rig looks good as is! How 'bout putting modern stuff in the old camper?
yuccales is offline   Reply With Quote
Old 12-11-2014, 08:09 PM   #3
70shtbx
Thanks yuccales, that's a possibility, still looking at options. She has a fair amount of dry rot and water damage though, but possibly fixable if I chose to go that route but a mix of the old and new would be cool.
Old 12-11-2014, 08:11 PM   #4
71swb4x4
71swb4x4's Avatar
There are a lot of people who build custom trailers. I would ask one of them if they can build you a camper to set onto your frame. Ice house builders, cargo trailer builders, restaurant trailer builders; they should all be able to help.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-11-2014, 08:18 PM   #5
70shtbx
Will do but I have to think that maybe I could buy a used camper , remove the axles, modify it a bit and put it on the frame, I may be all wet but we will see.
Old 12-11-2014, 08:31 PM   #6
rambler
MOVE OVER
rambler's Avatar
I like your ideas... old iron with some modern conveniences.. would take some planning to make it look right...
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 12-11-2014, 08:33 PM   #7
70shtbx
Well w/the help of this forum I think I could do it.
Old 12-12-2014, 11:20 PM   #8
cleanfreak
cleanfreak's Avatar
Been following the same thoughts also. How about removing the franklin , build a flat bed with outside doors like a service box , put a modern 10-12ft slide in (with a tip out maybe?)in it. If done nicely , you could make it all look like one unit. I've only seen one done like this , looked real good , guy used it to haul an of road race truck. You could still leave the camper removable so the truck could go inside a normal height garage for service.
cleanfreak is offline   Reply With Quote
