Old 12-11-2014, 09:18 PM   #1
asolde
asolde's Avatar
New rear side panels
Need some advice on how ot install these panels in my truck. Seems like they are to tight to fit into the chrome strip. In other words the panels are to high with the carpet installed on the wheel well housings to fit nicely into the chrome strip. Any ideas or what have you done to install your panels?
1) Elongate the mounting holes on the chrome strip to gain about an 1/8" higher in mounting the chrome strip. That would loosen the fit up a little but the chrome strip will be even with the top of the bed rails. Shouldn't look bad.
2) Take the carpet off the wheel well housings. Gonna be hard because I glued them on. But I would gain the thickness of the carpet and loosen it up a little.
3) There is no way for me to trim the panel so thats out of the question.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 12-11-2014, 09:27 PM   #2
SeventyOne
Re: New rear side panels
Elongating the holes seems like an ok option.
Or instead of removing the carpet from the tubs, why not cut them where the panel hits them so the carpet comes up flush with the panel but all material is removed under/behind the panel.
SeventyOne is offline   Reply With Quote
Old 12-11-2014, 11:49 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'd trim the carpet. I thought that the carpet for the CST models with the rear side panels only went up to meet the panels anyway. I've never seen it, just assumed since it is listed different in the catalogs and the carpet on the floor looks like it also stops at the panels.
Carpet kits are cheaper than the repop panels and the chrome strips are not produced.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-12-2014, 07:43 AM   #4
grillzy
I don't understand why the panels are not offered for carpet or without. I myself would pull back the bottom of panel and trim the backing board.
grillzy is offline   Reply With Quote
Old 12-12-2014, 09:21 AM   #5
68panelman
68panelman's Avatar
I'm with Bouncy on this one too.
68panelman is offline   Reply With Quote
Old 12-13-2014, 11:23 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Floor carpet does not go under the panels. Wheel hump carpet, like kick panel and door-bottom carpet, I'm pretty sure is an aftermarket-ism, and doesn't fit under them either. I would personally trim the carpet, as it's the cheapest option should something bad happen in the process...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-14-2014, 09:19 PM   #7
drillrod
Where did you get your side panels and carpet from? I am getting ready to purchase mine and BROTHERS is the only company I have found that offers blue side panels. Everyone else I have found only offers black!
drillrod is offline   Reply With Quote
Old 12-14-2014, 09:46 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Alex I experienced the same. I was able to wedge mine into place not trimming the carpet but believe I have more a more noisy ride as a result. I would remove a strip of carpet, which wasn't in place when the K5 left GM anyway. I matched my old with my new and used a marker to place the holes for the trim screws.
As an aside, I'm curious what you think of the quality. I felt these to be superior to OEM. The stitching is hand done from what I know. For others, these new panels use melamine-like backing rather than the cardboard found on OEM pieces.
Old 12-14-2014, 09:49 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Send a PM to member Truckseats - he supplies these.
Old 12-15-2014, 02:43 PM   #10
cleszkie
cleszkie's Avatar
I experienced the same issue when I installed my new side panels with carpet on wheel wells. I ultimately ended up gently peeling the vinyl off the backing board, trimming the board, and them reapplying the vinyl with staple gun. It is important to note that I had to trim not only the bottom edge of the boards, but I also had to trim around the wheel well opennings as well to get the panel to drop down and fit the wheel well properly. If you only trim trhe bottom edges, the panels will not drop down. It was a bit of work, but I didn't want to trim the carpet and chance it fraying without a proper hem on the cut edges, and I wanted to keep the carpet on the wheel well. I know it is hard to imaging cutting up your new $500 panels, but it is worth it after you see how nice they look installed. Good luck.
cleszkie is offline   Reply With Quote
Old 02-07-2015, 09:29 PM   #11
Jlo1986
Jlo1986's Avatar
Any pictures?
JLO
1972 Blazer 2WD
1986 Chevy Silverado (Black)
1986 Chevy Silverado (Blue)
Jlo1986 is offline   Reply With Quote
Old 02-09-2015, 06:23 PM   #12
cleszkie
cleszkie's Avatar
Not the best pictures, but you get the idea.
Old 02-09-2015, 09:45 PM   #13
drillrod
Cleszkie, is that a Hickey roll bar in your blazer? I was wondering if you could post some pictures of where the feet of the roll bar mount in relation to the side panels. It looks like they may partially be under the side panels. I am trying to fix a hickey roll bar that I bought that someone had shortened the legs on. Thanks a lot, Drillrod
Old 02-10-2015, 01:22 AM   #14
Blazerowner
Blazerowner's Avatar
The reason they don't fit is because there was never carpet on the wheel wells from the factory. Not sure if someone said that, but I didn't read all the posts. I would consider pulling the vinyl up a trimming the board like Cleszkie did. By the way nice sliders in the top.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 02-10-2015, 03:24 PM   #15
cleszkie
cleszkie's Avatar
Yes it is a Hickey bar. Two of the mounting bolts on each foot are under the side panel in my Blazer. However, these old roll bars were bent and welded by hand so the dimensions can vary from bar to bar. My bar originally was not centered properly on the mounting feet (too much gap between leg and side panel on one side). So I cut the mounting feet off and rewelded them so that the bar was centered properly. I don't know that pictures of my bar would help you out. You just have to do some dry runs with the fit and make adjustments accordingly. I think someone posted some dimensions of thier Hickey bar a while back that could help you, but I think the search function has been removed.
Old 02-10-2015, 05:56 PM   #16
richard2717
Equal opportunity joke ofender
richard2717's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=543001
Google search box up top still works just have to make sure to click on 67-72 trucks
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 02-10-2015, 09:14 PM   #17
drillrod
Thanks cleszkie, that helps a lot! By the way, NICE K5!
Old 02-12-2015, 07:20 PM   #18
Jlo1986
Jlo1986's Avatar
I just had these panels cut from a diagram on this site. I used 3/16 plywood.
JLO
1972 Blazer 2WD
Old 02-12-2015, 08:59 PM   #19
1956cameo
1956cameo's Avatar
Just a heads up to anyone who might be interested. The Truck Shop in Orange California has Blazer and Suburban side panels in Black, Blue, Green, or Parchment. They are listed for $550 a pair. I can't vouch for the quality because I have not purchase them yet but everything else that I get from the Truck Shop is good quality.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
