Old 12-12-2014, 03:20 PM   #1
wtrskinut
wtrskinut's Avatar
Gauge cluster question
I've heard the earlier year 73-75 clusters wont work in late 70's to mid 80's but I was wondering if a mid 80's cluster would work in a 75? Picked up a real clean one with a tach that I'd like to use.
wtrskinut is offline   Reply With Quote
Old 12-12-2014, 04:01 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Gauge cluster question
I don't know the exact years, just that the early squares had a mechanical oil gauge and amp gauge instead of volt gauge.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-13-2014, 10:48 AM   #3
Ski-me
Ski-me's Avatar
I think if you want to use the whole cluster as is, at a minimum, you would probably have to re-pin your cluster wiring harness. Even from an 89 to 91, I had to re-pin my connector to make the 91cluster work. It now works like a charm but did take a little time mapping and tracing everything.....
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
