Old 12-12-2014, 05:52 PM   #1
gramps77
drip rail screw size
anyone know what the screw size is for the drip rail above the door?
gramps77 is offline   Reply With Quote
Old 12-12-2014, 06:00 PM   #2
ray_mcavoy
Re: drip rail screw size
They vary by year.
I think most of the early ones were a #8 screw with a 1/4" hex head. I've seen a few with phillips heads but I don't know if those were original or not.
Sometime in the later 70's they changed to metric screws ... I think those are M4.2 with a 7mm hex head.
ray_mcavoy is offline   Reply With Quote
Old 12-12-2014, 09:36 PM   #3
Ziegelsteinfaust
Early ones 73 to maybe 75 Phillips. After that hex. The Phillips was a dealer add on I think
Ziegelsteinfaust is offline   Reply With Quote
Old 12-12-2014, 09:56 PM   #4
AntiGov
AntiGov's Avatar
My 88 is a 5.5 mm
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 12-12-2014, 10:25 PM   #5
Greenlee
Greenlee's Avatar
I don't remember what size they are, but I had kind of a hard time finding them when I put my truck back together. It seemed like every screw I found that was short enough to work was too small in diameter for the holes. Finally, I found some in stainless that fit perfectly at a local hardware store.
Greenlee is offline   Reply With Quote
