Old 12-13-2014, 01:43 PM   #1
yoshi
yoshi's Avatar
L/H wing to body bracket
Would anyone be able to give me the measurements of the bracket as mine is missing. Many thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 12-13-2014, 03:07 PM   #2
thunderjet
Re: L/H wing to body bracket
Assume you mean the drivers side front fender bracket. I can measure one of my spares for you, but it is curved so tell me which measurements you want.
thunderjet is offline   Reply With Quote
Old 12-13-2014, 04:03 PM   #3
Clarance J
Clarance J's Avatar
Hello Yoshi. Just a thought. You are asking for a L/H part, Could there be a R/H part that you could get measurements from? A lot of the body parts have a mirror image of themselves. Maybe a picture of where it bolts to would help.
Earl
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 12-13-2014, 06:10 PM   #4
yoshi
yoshi's Avatar
This bracket isn't on the passenger side as far as I'm aware. I don't have this bracket so I need as much info as possible to make 1 up, many thanks
yoshi's 49 project
Old 12-13-2014, 06:35 PM   #5
OrrieG
OrrieG's Avatar
I am confused, cannot think if any brackets that are not mirrored pairs. Photo of General area would help.
OrrieG is offline   Reply With Quote
Old 12-13-2014, 07:20 PM   #6
yoshi
yoshi's Avatar
Can see it in this pic but can't edit it to point to it http://www.speedprint.com/deves50/im...ncluley1lg.jpg
yoshi's 49 project
Old 12-13-2014, 07:45 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
if its this part its the same as the other side on trucks with a pedal type emergency brake
dwcsr is offline   Reply With Quote
Old 12-13-2014, 07:48 PM   #8
yoshi
yoshi's Avatar
Yes in the lower half of your circle
yoshi's 49 project
Old 12-13-2014, 07:52 PM   #9
FiftyTwo
FiftyTwo's Avatar
It's only used on the LH side of the truck. Sorry, I don't have one laying around to measure.
http://www.truckandcarshop.com/truck...og/t47_062.gif
FiftyTwo is offline   Reply With Quote
Old 12-13-2014, 07:53 PM   #10
Donaldo
Drivers side fender well bracket - my '51 doesn't have one on the passenger side, fender well bolts directly to the cab through the angled part of the floor.
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 12-14-2014, 12:55 PM   #11
oldman3
oldman3's Avatar
FiftyTwo is correct with the brake bracket in the lower left of his link.
#47-06030 for $49.00 and is for drivers side only. I took some pics and a few measurments from my son's AD. In the first pic the part bolted to the cab is 2-1/2" long, then bent down 1" and bent again 1". This part is narrow at the top and gets wider as it goes down.
oldman3 is offline   Reply With Quote
Old 12-14-2014, 12:59 PM   #12
oldman3
oldman3's Avatar
In this pic the bracket is further away from the cab floor and is approx 2" from flange at cab floor. Sorry for the bad pics.
Old 12-14-2014, 01:04 PM   #13
oldman3
oldman3's Avatar
In this last pic it shows where the bracket is attached at the lower part of cab. Overall length of the bracket from top to bottom is 18". This bracket bolts to the cab floor in 3 spots and these two a the bottom. Then the inner fender bolts to this bracket in 3 spots.
Old 12-14-2014, 01:12 PM   #14
oldman3
oldman3's Avatar
Here's a pic from the assy. manual that shows the bracket. From the photo in the link from FiftyTwo, my pics and measurements and this you might be able to fab a bracket. Hope this helps...Jim
Sorry I have to reduce size of file, won't let me load, back in a minute..Jim
Old 12-14-2014, 07:11 PM   #15
yoshi
yoshi's Avatar
Ok many thanks for that, looks a bit more complicated than I thought!
yoshi's 49 project
