Old 12-13-2014, 07:27 PM   #1
IdahoMan
The Wiper Knob
My wiper knob is broken, in half.
And for a replacement part you think would cost around $.99 max, the magazines deliberately want $13.00 for it. Nope.
Who else has repaired/glued-back-together their wiper knob? Or are there other replacement options?
-IM
IdahoMan is offline   Reply With Quote
Old 12-14-2014, 05:04 PM   #2
Axle
Axle's Avatar
Re: The Wiper Knob
Lots of options. A small control knob of a bit of discared electronics, surplus store, etc. that set with a set screw. I just put one into mine. Again.
If you have the D-shaft switch, you'll have it a lot easier as mini-D is relatively easy to come by. Most mini-d's don't use a set screw.
If you have the knurled round shaft switch, you can drill out a trimmer pot knob to fit and a set screw holds it in. You can use these on the mini-d also, just put the setscrew onto the flat.
https://www.google.com/search?hl=en&...earch+by+image
I suggest local sources so you can visually confirm the knobs shaft dimensions, there are many shaft shapes and sizes out there.
Alex.
Axle is offline   Reply With Quote
Old 12-14-2014, 05:40 PM   #3
MalibuSSwagon
Re: The Wiper Knob
My local Ace Hardware has an extensive hardware selection, including a bit of control knobs. maybe give them a shot?
MalibuSSwagon is offline   Reply With Quote
