Old 12-14-2014, 01:06 PM   #1
Cohl
Cohl's Avatar
Anybody ever recondition a shift knob?
Looking for a good way to make my shift and T/C knobs looks nicer. With all the use they see I just wonder what methods work if any...
Cohl is offline   Reply With Quote
Old 12-14-2014, 01:40 PM   #2
221racingGarage
Re: Anybody ever recondition a shift knob?
http://67-72chevytrucks.com/vboard/a...1&d=1418578707 Try polishing compound and a white filler crayon. this one turned out ok. it had a few deep scratches.
221racingGarage is offline   Reply With Quote
Old 12-14-2014, 01:45 PM   #3
Kennuck
Kennuck's Avatar
On my Willys I screwed in a bolt with the head cut off with the right threads for the knob. The I put that in my drill press and used fine sandpaper followed by polishing compound. Came up just like new, repaint the shift pattern and your done.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 12-14-2014, 02:26 PM   #4
68shortwide
68shortwide's Avatar
Pretty much did the same as Kennuck. Cut the head off a bolt, welded to a piece of tubing and threaded it into the knob, used a buffing wheel, turned out pretty nice.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 12-14-2014, 03:29 PM   #5
davepl
davepl's Avatar
Yep, the trick part is to get it chucked into a drill. Then you set a piece of wet sandpaper in a couple of rags and run the drill if you need to get out some serious scratches.
I did my auto shift knob that way, stepped through the grits to about 1500, shot it with clearcoat. HOWEVER you are dealing with depressed (engraved) gear position indicators that limit your ability to knock down the surface without obscuring the letters, so you need to be way less aggressive than I was.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
