Old 12-14-2014, 03:40 PM   #1
dtkarst
Having a starting problem
Ive been driving my C20 lately and took it out for a spin last night to see how my lights and stuff all work and when i got back i parked it for a few minutes then tried to start it again and now the only way it will stay running is if i hold the key in the start position and leave the starter spinning. As soon as I let off the ignition it dies. Anyone ever experience this issue? Cant move it much when i have to hold the key in the start position for it to run,
dtkarst is offline   Reply With Quote
Old 12-14-2014, 05:41 PM   #2
Jimal
Jimal's Avatar
Re: Having a starting problem
Are you getting power to the coil with the key in the "on" position? Sounds like you might have popped a fusible link or a ballast resistor, assipumng these trucks have either (I'm speaking from General ignition system knowledge, and not specifically about these trucks.)
Jimal is offline   Reply With Quote
Old 12-14-2014, 05:45 PM   #3
dtkarst
Well it's got a brand new hei distributor and a new ignition. It'll run as long as I hold the key all the way over
Old 12-14-2014, 06:19 PM   #4
j.kirn
you need a new ignition switch
j.kirn is offline   Reply With Quote
Old 12-14-2014, 06:29 PM   #5
dtkarst
That was my guess after checking things over..if only parts were meant to last.
Old 12-14-2014, 06:58 PM   #6
Jimal
Jimal's Avatar
That additional information might have helped...
I'd check the wiring too.
