Old 12-14-2014, 06:02 PM   #1
grs
Tire removal on lowered truck.
My truck is lowered 4 inches on the rear. To remove the spare if I get a flat I use two scissors jacks. I had a 5/8s half inch socket welded to the end of each jack. Got two half inch extensions. Put one jack under the rear end near the wheel. Raise the wheel up. Put the other one under the bumper, or the frame, and raise the body up so the wheel will clear the side of the bed. I cut a 4x4 in 12 inch lengths. 4 of them. Screw 2 of them together. You will have two sets
grs is offline   Reply With Quote
Old 12-14-2014, 07:00 PM   #2
jjzepplin
jjzepplin's Avatar
Re: Tire removal on lowered truck.
I never thought about this problem. I just did an axle flip on mine and have stock steelies so I might be OK. But what about the guy that has 10" rears and can't see the lugs at all cuz it's so low? Roadside assistance may not even be able to help. I guess they air up the bags and change the tire then?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-14-2014, 07:40 PM   #3
LVPhotos
LVPhotos's Avatar
I jack mine in front of tire on flat spot on frame. The axle drops out and tire can be worked out. Or 4x4 spread across rear frame. I don't trust scissor jacks. I have had them fold under load.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-14-2014, 08:24 PM   #4
grs
The jacks I used were from a Toyota, and a Honda. Not sure how strong they are. I use two so they might be OK.
