Old 12-14-2014, 08:05 PM   #1
crazyjim
crazyjim's Avatar
Fuel tank
Anybody got pics of how they Installed their fuel tank neck and cap to the rear of the bed?
crazyjim is offline   Reply With Quote
Old 12-14-2014, 08:32 PM   #2
FarmerSid
FarmerSid's Avatar
Re: Fuel tank
What year you look'in for?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 12-14-2014, 08:48 PM   #3
Rude Dude
Rude Dude's Avatar
Re: Fuel tank
Depends what fuel tank filler tubes size is on the tank, some are small tubes such as 1 1/2 diameter and some tanks are 2 to 2 1/2. Filler caps also vary in size but are normally attached to tank with gas rubber hose with clamps. For mine I bought a threaded gas cap with a bung from SoCal speed shop that I can weld tubing to like an exhaust tubing for the correct size. The prices vary on these filler tubes at the store from $40 to high tech billet ones with all the bells and whistles for $250.
Rude Dude is offline   Reply With Quote
Old 12-14-2014, 10:00 PM   #4
crazyjim
crazyjim's Avatar
Re: Fuel tank
It's a 1948 5 window.just looking to see how people mounted their necksin the pickup bed.
Old 12-14-2014, 10:09 PM   #5
crossfire84
crossfire84's Avatar
Re: Fuel tank
check out my build.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 12-15-2014, 10:40 AM   #6
roger55
roger55's Avatar
Re: Fuel tank
This is what I did:
roger55 is offline   Reply With Quote
Old 12-15-2014, 12:45 PM   #7
crazyjim
crazyjim's Avatar
Re: Fuel tank
Thanks guys, getting some good ideals But i would like to come up through the bed floor so it's out of sight.
Old 12-15-2014, 04:04 PM   #8
OrrieG
OrrieG's Avatar
Re: Fuel tank
Rear tank, fleetside bed, side fill. Dodge Caravan donor door.
OrrieG is offline   Reply With Quote
Old 12-16-2014, 02:01 PM   #9
Advanced Design
Advanced Design's Avatar
Re: Fuel tank
Did this on my 48. Tank is a top fill from Tanks.
The fill surround was a chrome plated sink drain from the hardware store. Cut the center out with a lathe then the top and bottom portions of the drain screwed together sandwiching the board.
Advanced Design is offline   Reply With Quote
Old 12-16-2014, 04:14 PM   #10
Highsider
Highsider's Avatar
Re: Fuel tank
Clever and a clean look, Advanced Design!
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 12-16-2014, 04:27 PM   #11
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Fuel tank
Outstanding look, Advanced Design. I like it for my truck. Ingenious to use the sink flange. I don't have a lathe but I imagine I could file out the opening to fit. Kind of a pain but it doesn't seem like I'd have to remove all that much?
Can you tell us what the tank number is you bought from Tanks, Inc?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 12-16-2014, 04:58 PM   #12
starterman99
starterman99's Avatar
Re: Fuel tank
pictures did not work
1950 5 window
starterman99 is offline   Reply With Quote
Old 12-16-2014, 05:06 PM   #13
starterman99
Re: Fuel tank
this is how I did my 57
1950 5 window
Old 12-16-2014, 05:53 PM   #14
Advanced Design
Re: Fuel tank
Thanks guys - Dan the sink drain cost $17 and worked pretty well. It was a bit tight to the fill cap.
Here is a link to the tank I used-
http://www.tanksinc.com/index.cfm/pa...rod/prd129.htm
And a pic underneath.
Old 12-16-2014, 07:13 PM   #15
Dan in Pasadena
Re: Fuel tank
Thanks for the fast response. That tank drops in from the top and bolts directly to the frame upper flange, right? My only concern about that is IF I ever needed to drop the tank, I'd have to remove the bed or least loosen and raise it.
That tank is priced exactly same price as the Tanks, Inc. Universal tank
http://www.tanksinc.com/index.cfm/pa...rod/prd279.htm
...and has the same capacity but yours seem like it would show less from the rear with the taper built into the bottom. Hmmm, gonna have to think this one over.
Old 12-16-2014, 07:49 PM   #16
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Fuel tank
You can use a 67-68 Camaro tank if you want a side fill or a 69 Camaro for a rear fill. I used a 67-68 and did the side fill out the rear fender on a 50
dwcsr is offline   Reply With Quote
Old 12-16-2014, 08:12 PM   #17
Advanced Design
Re: Fuel tank
I tried the universal you mentioned and it extended too low. This tank was raised up on a support...and would probably have to remove the bed to remove the tank. Could probably build around that issue.
Old 12-16-2014, 08:19 PM   #18
Dan in Pasadena
Re: Fuel tank
Originally Posted by Advanced Design View Post
?...This tank was raised up on a support...and would probably have to remove the bed to remove the tank. Could probably build around that issue.
Hmm, like a spacer between the tank and the upper frame flange? I haven't looked lately but there doesn't seem to be too much space there. Maybe an inch?
But I suppose every bit would help to minimize seeing the tank from the rear.
