![]() Join Date: Nov 2004
Reupholstered my bench seat.
I started with new foams and spray glued new burlap (walmart was useful for a change) onto them.
Unfortunately the foams I bought were for the comfort package? seat frame. This is the frame that has the springs dropped lower for more foam. I've only ever seen a couple of these seats, and after looking for a few months for a donor frame I gave up and decided to just cut mine (foam) apart. I reshaped it a little better after the pic and glued burlap over it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: Reupholstered my bench seat.
Aside from having a good bit of surface rust issues, my frame was in extremely good shape. I hit the surface rust with a wire wheel and scuffed down the rest with a red scuff pad. I put a couple quick coats of rustolium semi gloss on it.
I started with the top. I worked it until I got the lines as straight as possible.
Then I finished up the bottom today. Bottom was a little tougher as you had to really stretch it.
Also, something I didn't take a pic of, was I did it once and noticed the ribbing for the frame poking the seat material. Not cool. So I removed the front of the cover (only had a few hog rings in at the time) and glued a strip of foam from the old seat along the face. It is visible (was visible with old seat cover too) but at least I know it can't "cut" through. I think my new seat foam was just slightly too small?
I had to cut a few holes in the new material (always scary!) and screw the top back on.
Covering up the sides wasn't too hard either. There's a few very minor wrinkles I'll take my heat gun too when I get time, but for now I have a "new" seat ![]() This IS a project you can do at home. I highly recommend buying the "good" seat cover. They have a thicker vinyl. Sorry, I don't remember the brand, I bought it 3 years ago from Tim Christian. Just take your time, go slow, start from the middle and work your way out.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 12-14-2014 at 10:23 PM. |
This also isn't my first upholstery job. I think I kinda like it. It's a challenge to get all the wrinkles out and get the piping to work.
My mustang Before: After (same seat frame!!!): Back seat:
Seats look awesome man! Great job!
looks good. I had a seat recovered one time . they put too much padding in itand I could barely squeeze in behind the wheel
Old member
Yepper's great job there Jessie!
Now are you going to drive it on the 2015 HRPT? That is the question. ![]() ![]() ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
That bench seat looks great, you do awesome work.
Scott |
Lurky lurky
Looks awesome, you have a lot of patience, your projects always turn out well. I know what you mean by cutting new upholstery. I just did Katzkins in my DD and had to trim for headrests, armrests, and plastic panels, pretty scary cutting into brand new stuff!
Thanks guys. I'm a little sore today. The top was easy because of how far the back "slips over" the frame, you really only need to pull/work the bottom end. I'm a little sore from pulling the bottom cover, then taking the front off to add that extra foam around the face of the frame, then pulling it again.
I had to get my deck project finished up so I didn't get a chance to do the brackets.
#13 |
![]() Join Date: Apr 2005
Nice.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
