Old 12-14-2014, 11:26 PM   #1
1972BlueC20
1972BlueC20's Avatar
low fuel pressure, HELP!!!
New engine installed. I've tried 2 different mechanical fuel pumps and 4 different fuel filters and still getting 2.5-3 psi after truck is at full operating temperature. It starts out at 6 psi at cold start. Trucks running ok even after pressure drops, but I don't think it's right. Also getting air bubbles in the filter after pressure drops.
My next move is to check sock on sending unit, then replace fuel line from tank to pump.
Is there anything else that could cause low pressure??
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 12-15-2014, 10:07 AM   #2
1972BlueC20
Re: low fuel pressure, HELP!!!
Any ideas guys?
Old 12-15-2014, 10:24 AM   #3
Lee H
Lee H's Avatar
Air bubbles in the filter are normal. Which pumps, stock replacements? Which pressure gage, how is it installed? Is the filter before or after the pump? I still think it's the 6 or so feet of rubber hose between the tank and the pump.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-15-2014, 10:27 AM   #4
MARKDTN
3PSI is OK for a carburetor on a street driven, relatively low RPM application. Probably bottom end, but OK.
Replacing the sock is a good idea, it won't hurt. You can blow out the lines and see how much crud is in them.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-15-2014, 10:41 AM   #5
1972BlueC20
Well the engine came with a Holley carb, so I put a Holley mechanical pump on first, then I wasn't happy with the Holley carb so I put my old Edelbrock back on and I went and got the Edelbrock 1721 fuel pump so it would match the carb. Same problems and same pressures with both pumps.
The gauge is an aeromotive brand liquid filled gauge that is mounted on the fuel line going into the carb after the filter.
The filter is after the pump just before it goes into the carb.
As for the rubber line, I'm probably going to replace it with stainless lines very soon, but assuming the lines are clear and not clogged in any way.....could just being rubber cause low pressure?
Old 12-15-2014, 10:44 AM   #6
slomotion
Old Duffer
slomotion's Avatar
Before I started chasing ghosts all the way back to the fuel tank, I'd do a couple of simple tests. Are you sure the gauge is accurate? What are the specs for your pump, and what is normal? Are you sure it's "broken"? What engine are we talking about? How close does your fuel line get to the engine...is it picking up a lot of heat from the intake manifold? I'm assuming this is a carb'd engine. Is it possible the bubbles you're seeing are from the fuel getting over heated? The first thing to do would be check the fuel pressure at the pump discharge. That should remain pretty constant, if the fuel lines are too close to the engine, move them out a little. If it's running OK, hot and cold, take the truck out to a safe place and see if it stumbles under load at highway speeds.
These are just a couple of ideas. If you give us a little more info, we may be able to help more.....
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 12-15-2014, 10:51 AM   #7
1972BlueC20
I'm not sure the gauge is accurate, that's on my list to check sooner rather than later. It's a brand new gauge, but it could be defective.
As for the specs of the pump, I haven't been able to turn up much from a google search as to whats normal pressure. All I know is that the Edelbrock 1721 has a max pressure output of 6 psi. It's starts at 6 psi when cold, but then drops to 3 psi.
The lines and filter are running about 4-5 inches away from the exhaust manifold and engine itself. I don't think it's a heat issue. The lines and filter are cool to touch even after the truck is fully heated up.
The truck runs good, no stumbles or significant hesitations.
I'm having some other issues with my kickdown cable not working right now, and I think it could use some carb adjusting and some timing tweaking to get the performance up to par, but as for just normal driving it runs good and has plenty of daily driver power.
The engine is GM 350 part # 1921008. 330 Hp Crate Engine
http://www.summitracing.com/parts/NAL-19210008/
Old 12-15-2014, 10:51 AM   #8
geezer#99
geezer#99's Avatar
If you take it out and take it to max rpm in each gear and it doesn't quit or bog, then you have a vision problem.
Simply remove those things your eyes see but your brain can't process!
Remove the gauge and plug the hole.
Put on a filter you can't see into.
Done!!
Old 12-15-2014, 11:10 AM   #9
1972BlueC20
Here is a video I made of the issue from the other day.
I know the filter appears too close to the exhaust manifold in this video, however it's really not as close as it looks.
I've since moved the filter about 4-5 inches away and up from the exhaust and engine block.
The filter and fuel lines are cool to the touch with the engine at full operating temperature.
I've also since replaced the filter with a metal filter that is not see through. Still having low pressure.
https://www.youtube.com/watch?v=OQ1J...ature=youtu.be
Old 12-15-2014, 03:05 PM   #10
cleszkie
cleszkie's Avatar
Is your fuel tank vented properly? Sounds like you are generating some vacuum with the fuel pump that is preventing full flow (and pressure) potential. On cold start, there is no vacuum built up, so the pump delivers full flow and pressure. As pump continues to pull fuel, a vacuum begins to build up in tank, which impedes fuel flow and therefore reduces fuel pressure. Fortunately for you, it sound like the vacuum is being slowly released such that the pump is able to maintain 3 psi and keep you engine going. If the vacuum was not slowly bleeding off, it bwould build to the point where the pump would not be able to pull any fuel.
cleszkie is offline   Reply With Quote
Old 12-15-2014, 03:16 PM   #11
1972BlueC20
Yeah I'm really thinking it's a tank issue the more I think about it.
My tank isn't vented since it's a C20, it did originally have 1 main feed line and 1 return line. Since I'm using new pumps with only 1 in and 1 out, I've capped the return line at the tank and just using the main feed line. When I remove the gas cap, there is never any pressure or release.
I tried another cap recently, and it was causing major pressure build up. It was sealing too well. After the truck ran for a while and the pressure would drop, I'd take the cap off and it would blow air out (release pressure)
The truck also wouldn't restart if killed and you tried to restart unless you removed the cap and released the pressure first.
Because of this, I switched back to the original cap.
Old 12-15-2014, 03:30 PM   #12
davepl
davepl's Avatar
Better not be. Long runs of rubber fuel hose under a vehicle (or anywhere) is just asking for immolation. Yeah, it's easier. Don't. That should be and needs to be steel line, and then Lee's concern with the rubber line goes away.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-15-2014, 03:31 PM   #13
davepl
davepl's Avatar
Is it worse with a full tank than an empty tank? If so, that would back the vent theory. If the tank is empty there's more air space for it to evacuate, but fuel doesn't expand, so if the tank is closer to full, it should create the vacuum issue sooner. Just a thought.
Old 12-15-2014, 03:40 PM   #14
1972BlueC20
I have the same problem regardless of how full the tank is.
Where is a good place to find steel fuel lines, perhaps locally....do auto parts houses have steel lines?
Old 12-15-2014, 03:57 PM   #15
MARKDTN
Didn't you pay big bucks for a shop to install this engine for you? Do they have any thoughts? If you capped the return line and have a non-vented tank, as mentioned above that could well be it. Take the fuel cap off and see if pressure improves. I also agree that air bubbles are not good. If you replace your lines, don't just buy steel lines without ends-buy premade ones that have the correct barbs at the ends that hold the hoses on (keep the clamps from sliding off).
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 12-15-2014, 04:11 PM   #16
1972BlueC20
yeah i'm a bit pissed off at the shop....they screwed up a few other things...I had to fix some vacuum lines that they had ran wrong....lets just say I won't be using them again...also as for this problem....I took the truck back to them and they said the pressure was good with no bubbles the whole time they had it....and of course, as soon as I get home after picking it up from them, low pressure and bubbles....I'm done with them!!
I just want to fix this myself. I prefer never to deal with them again.
As far as getting original style steel lines......because I'm not using the original style pump, I don't think the fuel line will line up with the inlet on my Edelbrock pump. Would it be ok to use a small 2-3" section of rubber line to connect the steel line to the fitting on the pump?
Or if not, what can I do about this?
Old 12-15-2014, 04:27 PM   #17
MARKDTN
Yes, a few inches of rubber line is OK.
Lets slow down and take a big-picture look.
-new engine with Holley carb and Holley mechanical pump (did that come with the engine? What didn't you like about the Holley?)
-changed to Edelbrock carb and Edelbrock mechanical pump
-blocked the return line to the tank
-changed to non-vented fuel cap
-various filters and lines and hoses and routings from pump to carb
I would get a 1 gallon gas can and drop the suction line into it. See if pressure improves. If not, then you have pump or lines to carb issues. If it does, then fuel tank/line/cap/hose issue(s).
Might consider going back to a 3-line stock mechanical pump and using the factory return line. Unless you are racing, that should be adequate flow for you. I'm betting on fuel cap issue and/or an issue with blocking the return line.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 12-15-2014, 04:36 PM   #18
davepl
davepl's Avatar
Yes, and there's normally a short section like that that connects the tank line coming out of the bottom of the cab to the steel line on the frame rail. You need those two sections just for flex between engine/cab/frame.
Old 12-15-2014, 05:04 PM   #19
ssxty8
Lightbulb Re: low fuel pressure, HELP!!!
"The gauge is an aeromotive brand liquid filled gauge that is mounted on the fuel line going into the carb after the filter."
I bet your problem is the fuel pressure gauge. Being it liquid filled, the atmospheric pressure when it was filled with liquid is different than when you runnit and it gets hot. Try lifting the little rubber plug at the fuel gauge's bezel, when you notice low pressure indication, and see if it goes up.
Hope this helps.
ssxty8
ssxty8 is offline   Reply With Quote
Old 12-15-2014, 05:14 PM   #20
brown7373
brown7373's Avatar
I've been reading this thread, and have a question. Does a mechanical pump produce more pressure with higher rpms, like an oil pump, or is it constant? Logically, it seems like it ought to produce more pressure at higher rpms.
brown7373 is offline   Reply With Quote
Old 12-15-2014, 05:15 PM   #21
1972BlueC20
Ok.....let me try to tell you exactly what happened in order from earliest to most recent....please excuse the long post that's about to ensue....
The engine came with a Holley 670 vacuum secondary carburetor and no fuel pump. I purchased a Holley fuel pump because I wanted the carb and pump to match.
The shop called me after doing the install and said my truck was ready but it had a delay kicking in the secondaries when accelerating hard and they weren't really thrilled with the engines performance. They blamed it on the carb. They tried to say something was internally wrong with the carb and that I should send it back. I wasn't happy with this explanation, but until I could drive it for myself I didn't know how good or bad it really drove. They also said the transmission kick down wasn't kicking down into gear upon hard acceleration. They said they adjusted the cable all the way out but couldn't get it to work. I figured they just did something wrong here and I could fix it later. Also, I recently had my transmission rebuilt a few months back, so I still have a warranty on the transmission. So I wasn't too worried about that at the moment.
I went to pick up the truck and I barely made it home it was running with such a hesitation, only upon above average acceleration. Normal driving seemed fine.
I almost turned around and took the truck back immediately, but I had picked up the truck near closing time and they were already gone for the day. So, I just crawled home.
Right near my house is a gas station and I was low on gas so I stopped to get a little fuel. I left the truck running and popped the hood and this is when I first noticed the pressure was about 2.8 - 3 PSI.....with bubbles in the filter. I shut the truck off, fueled up and got home as fast as I could.
After I got home, I called the owner of the shop and expressed my disappointment....he apologized and said I could bring it back and they would fix it.
While I was waiting to have the time to take the truck back (2 days), I was starting the truck a few times per day while it was sitting in my driveway....it was flooding real bad....barely starting and having low pressure issues.
I noticed that they left my return fuel line hooked up to the tank but just open at the pump side. I told the owner of the shop this, and he said it should have been plugged. He told me I could try plugging it and see if that helped....I did and it didn't help.....he then told me to try another fuel cap....so I did and the new cap fit very tight and caused a very good seal....so much so that after it ran for a while, the pressure was so great that if you took the cap off it would release a TON of pressure. Also, if you shut the truck off after it had ran for a good while, it would not restart again unless you released the pressure in the tank first. I decided to just put the old cap back on and take the truck back to the mechanic shop for them to make it right.
2 days later I took the truck back to the shop.....after they had it for 2 days they still couldn't get the Holley running good...they got it running better but still not right....it still had a hesitation and was still slow kicking in the secondaries...it also kept flooding and was very hard to start sometimes.....they basically threw their hands in the air and said they couldn't make it run any better and something was indeed wrong with the carburetor....this is when I started realizing they obviously weren't a good idea to have used for my engine install....but it was wayyyy too late at this point.....before this, they seemed great.....they could talk the talk....but until now, I hadn't seen them try to walk the walk......I know several people who have used them without issue and I do business with the owner....this is why I picked this shop in the first place.
So I decided to have them put my Edelbrock carb back on because It ran good on my original engine....I also decided to have them swap the Holley pump with an Edelbrock pump because I know Edelbrock carbs don't like more than 6 PSI, and this Edelbrock pump puts out a max of 6 PSI.
At this point, I just wanted to get my truck away from them!!!
Anyways when I went to pick my truck up, I made sure to test drive it first this time and it was running a lot better and the pressure was good during the test drive and afterwards so I took the truck and left....upon getting home the pressure was down again and it was getting bubbles in the fuel filter again...however this time, it was running good despite these problems....
So this is where I am now!
Truck runs pretty good, but has low pressure and air bubbles in the line. My kick down cable also isn't working still.
They had also ran my vacuum lines incorrectly and I just fixed all that yesterday.
I'm super frustrated!!
Old 12-15-2014, 05:26 PM   #22
MARKDTN
... I'm betting on fuel cap issue and/or an issue with blocking the return line.
Still my recommendation after seeing the big picture.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 12-15-2014, 05:34 PM   #23
ssxty8
I imagine they weren't trying to see the secondaries opening with the engine running and the car standing still. They "normally" just work with the car running/moving, due to vacuum generation, unless somebody mess with the linkage. In the Holley web page used to be a section regarding vacuum secondaries testing, which involved using a paper clip on the vacuum canister rod, and running the car. I did it in my 600 vacuum secondaries carb, and worked right. Then I installed a kit, which comes with different springs/colored for the diaphragm, to make them open faster, "but with the car running", not standing still. Hope I made myself understand. Again, check by lifting the rubber plug at the gauge with your nail, making sure it is positioned upwards, or the oil inside the gauge will came out.
Old 12-15-2014, 05:45 PM   #24
1972BlueC20
I think on my way home today i'm going to buy another fuel gauge and try that first, if it's not a defective or faulty gauge then I will get a gas can and try putting the suction line directly in the can.
I'm going to run new lines anyways regardless so I'll take the seat out and check the sending unit sock too while I'm back there.
Old 12-15-2014, 05:46 PM   #25
ssxty8
New gauge? This time try a dry one. Not oil filled.
