Old 12-15-2014, 12:03 AM   #1
zicc1835
zicc1835's Avatar
Help with Bagging the Back
i am thinking about putting bags in the rear only. I am going to use this truck for towing my car trailer . i don't want a compressor just want to fill the bags when towing and deflate to a smoother ride when i am not any suggestions what type bags or is there a kit available ? its a 71 1/2 ton SWB stepside thanks
JZ
zicc1835 is offline   Reply With Quote
Old 12-15-2014, 01:08 AM   #2
67ctener
67ctener's Avatar
Re: Help with Bagging the Back
Sounds like your looking for bags with schrader valves. It will allow you to do exactly what your looking for and fairly cheep. As far as bags I would imagine one with a good rating for weight and quality.
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 12-15-2014, 08:31 AM   #3
If your truck isn't lowered you can buy Air lift or Firestone bags. They are sold as auxiliary springs and insert inside the coils. they provide a lines and valves to mount at the rear bumper area.
My project has a 4/6 drop, which is too close for comfort w/o a notched frame for me. I want to tow and haul and definitely don't want to hack a good frame, so I'll be installing bags that replace the coils. I like the leveled look of a 4/6 drop, but also like trucks with some rake. rake was the rage in this era and my truck's them is era correct. With the bags I can have it both ways
Old 12-15-2014, 09:36 AM   #4
slomotion
Old Duffer
slomotion's Avatar
Just curious, why no on-board compressor? I put a relatively inexpensive Air Ride system with a small compressor in mine years ago and haven't had the first problem with it. The compressor can be held in one hand, and with the touch of a button the ride height of the rear end can be modified to compensate for load/no-load. The bags replaced the coils altogether, but I did retain the over load springs as an emergency measure to get off the road should the bag system fail. I don't think adding the compressor is any more troublesome than having to manually inflate/deflate a system, and the truck "rides on air" all the time.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 12-15-2014, 01:32 PM   #5
coop34
Zicc: I just did this last weekend and ran schraders to the rear license plate. Really simple:
http://67-72chevytrucks.com/vboard/s...d.php?t=129463
Or you can do something like Special K recommended. See Post #6:
http://67-72chevytrucks.com/vboard/s....php?p=4303241
Coop34
70 Chevy C10 5.7L TBI/700R4
coop34 is offline   Reply With Quote
Old 12-15-2014, 02:19 PM   #6
scottybaccus
scottybaccus's Avatar
If you have rear coils, I highly recommend the Firestone or Air-Lift Company bags that go inside the coils. I have used them extensively with my hauler. I kept a small air compressor behind the seat and inflated when needed, and let them down to minimum, otherwise. I probably logged 20k miles and hauled dozens of cars with them.
Scotty Baccus
scottybaccus is offline   Reply With Quote
Old 12-15-2014, 10:45 PM   #7
zicc1835
zicc1835's Avatar
thanks Scotty and to all the rest of the replies ...can you use the ones that go inside, with 6 inch lowering coils and does it change the stance i have a swb ss I am using as my hauler RV cam in a 327 with M20 and 373 posi so i need to decide just bags or what you and SpecialK recomends
thanks
Jess
Old 12-15-2014, 11:48 PM   #8
zicc1835
zicc1835's Avatar
i have a 4-6 lowering kit from ccp but id rather use bags in rear all same reasons and towing
