Old 08-19-2003, 05:58 PM   #1
rin68
rin68's Avatar
neutral safety switch
can anyone help me find the neutral safety switch/associated wiring on a 68 chev? it was orginally a 3spd manual on the column. i'm trying to find the wiring/switch but maybe it was removed by a previous owner?? if anyone knows what color wires i should look for that would be great. thanks
1968 C10 - 383, non-stop project
1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies
rin68 is offline   Reply With Quote
Old 08-19-2003, 06:47 PM   #2
junkyardjohn
junkyardjohn's Avatar
Lightbulb
I DON'T BELIEVE STICK SHIFT TRUCKS CAME WITH PROVISIONS FOR A NUETRAL SAFTY SWITCH IN THE WIRING HARNESS. SOMEBODY CORRECT ME IF I'M WRONG, BUT I THINK THE NUETRAL SAFTY SWITCH WIRING WAS ONLY AVAILABLE ON AUTOMATIC TRANS. EQUIPPED TRUCKS. AN AESY FIX WOULD BE TO REPLACE THE UNDER DASH HARNESS WITH ONE FROM AN AUTO EQUIPPED VEHICAL. THE WIRES YOU ARE LOOKING FOR ARE PURPLE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-19-2003, 08:29 PM   #3
JimKshortstep4x4
Smile
I agree with John, the sticks did not have the wiring setup and changing out the harness is an excellent way of getting the wiring you need.
It is possible to interrupt the large purple wire that goes to your
starter solenoid by cutting the wire, soldering in the right length pigtail with the correct plug and using that to plug onto your neutral safety switch.
I prefer John's suggestion as problems can develop with the connections as the purple wire carries a lot of current when starting the engine.
Jim
Old 08-20-2003, 12:04 PM   #4
rin68
rin68's Avatar
so i'm not going insane, it was never there in the first place. thanks for the help
Old 08-20-2003, 10:03 PM   #5
RShaips
I just replaced mine.top of column close to the firewall. Automatics only.
RShaips is offline   Reply With Quote
Old 08-21-2003, 11:35 AM   #6
rin68
rin68's Avatar
i think i'll wire a relay or something like that to do what i need.....or just forget about it and wait till the painless harness goes in next spring.......
Old 08-21-2003, 02:16 PM   #7
COBALT
COBALT's Avatar
Yeah, I think there's a relay down next to the case for just when the transmission is in reverse. No neutral safety though.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
