Old 12-15-2014, 09:51 AM   #1
RBrueschke
Question do you think it will fit?
Chevrolet Performance 454ci/7.4L L19/L29 Engine
Product images may differ from actual product appearance.
Free Shipping!
The Chevrolet Performance 454ci/7.4L L19/L29 Engine is designed as a stock replacement, providing the big torque you need for pulling a trailer or other heavy loads, for 1980-2000 Chevy/GMC trucks, SUVs and vans with a VIN build code of L19, L29 or LE8. These engine assemblies feature all-new genuine Chevrolet internal parts, new design enhancements and improvements are incorporated while they are built to the same exacting engineering standards that go into every new GM vehicle. They are tested to make sure that they perform under even the most demanding conditions!
Features: •4-Bolt Main Cast iron block
•Cast, externally balanced crankshaft
•Cast steel connecting rods
•Shot-peened and magnafluxed
•Pistons
•Hydraulic camshaft and lifters
•Cast iron cylinder heads with oval ports
•Oil pan
•Timing cover
GM Warranty
RBrueschke is offline   Reply With Quote
Old 12-15-2014, 11:18 AM   #2
pdxhall
pdxhall's Avatar
Re: do you think it will fit?
Sure will. Do a little searching, there are a bunch of them around here.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 12-16-2014, 02:02 AM   #3
Captainfab
60-66 Nut
There are a few different ways to install a big block, but yes it can be done.
