Old 03-28-2002, 10:16 PM   #1
dave's70
Post one piece driveshaft
I heard that you can use the driveshaft from 73 and up trucks, but does this include the 3/4 ton ones working on a 1/2 ton?
70 C-10 350 with weind intake,eldelbrock carb,HEI,305 heads,and a mild cam
70 C-10 350 with weind intake,eldelbrock carb,HEI,305 heads,a mild cam. also a blazer tank w/bed fill,shaved stake pockets and tailgate
dave's70 is offline   Reply With Quote
Old 03-28-2002, 11:42 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
not many 73-up 3/4 tons used one piece, you could also use a car shaft out of a big car preferably one with th350 or 3 speed so the yoke is same for tranny.
Just depends on if you find one long enough that you can cut down to use in your truck correctly, tape measure is your best friend when doing this, measure from the end of your tranny output shaft back to the U joint cup seat in the axle yoke and then go junkyarding until you find a shaft in something thats same length or just a hair over the length, just as long as you dont have to cut more length out of the shaft to make it work than you have to work with, IE past where the shaft diameter enlarges at either end
Randy- Lincoln, IL
randy@ccaonline.com
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28 H.O. 305 L69 700R4 GT4 3.73
- 1984 Firebird SE 2.8L T-5 GT4 3.73- whether to drive it or part it, hmmm...
-1981 Cutlass Supreme, dunno what im gonna do with it yet... part it ?
-79 G20 pass van, 350/th350/10bolt
*Paint is overrated
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited March 28, 2002).]
Fast68Chevy is offline   Reply With Quote
