Leaf Spring Centering Pin Size?
Do any of you know what the length and diameter of the center pin is for the rear leaf springs on my 1980 C10? It has the standard duty spring packs (NOT Heavy Half), with only three main leaves and an overload.
The reason I'm asking is that I'm making a "zero rate" lowering block to fine tune the ride height, and will need to pick up a new center pin. Thanks! |
| Bookmarks |
