Old 12-15-2014, 06:21 PM   #1
SCOTI
SCOTI's Avatar
Replacement Lenses
I want to get some replacement lenses for my dually project. I'm not interested in LED or new style clear lenses & prefer to keep things OE appearing as far as the trim goes.
What have you used & were you happy w/the quality?
I need:
  • tail light lenses w/chrome trim
  • front dually box side marker lenses w/trim
  • rear dually box side marker lenses w/trim
  • front fender side marker lenses w/trim
I have searched the net. I found several sources but it seems only a couple have everything & I'm not sure of their supplier (thus quality; I've seen some repop tail lenses where the chrome trim was loose as can be out of the box).
My search for NOS stuff will continue, but I always like to have a Plan-B.
Thanks....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-15-2014, 08:07 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Replacement Lenses
Scot, you're gonna puke at my answer, but I use Certifit for my lenses. Local and they fit just fine. Never had one of the notorious loose trims on any of them either (I have on mail order lenses though). They're in south Arlington. Cheap, and you unbox them and look at them with your own two eyes before walking out the door with them.
Old 12-15-2014, 08:10 PM   #3
dfrank
dfrank's Avatar
The two new tailight lenses I got from lmc truck a few years ago where GM lenses. I don't know if they are still selling the GM ones or not. May have to call them. Classic Industries used to have GM ones as well.
dfrank is offline   Reply With Quote
Old 12-15-2014, 08:18 PM   #4
dfrank
dfrank's Avatar
I just checked the new classic industries catalog and they still have original gm tail lamp lenses.
Part # without chrome trim
-LH G2360
-RH G2361
I think you can get replacement chrome trim for them to.
They also have GM fender marker lights although they don't have the trim and I am not sure if that is available. Even Classic Industries reproduction stuff has always seemed to be high quality to me.
Old 12-15-2014, 08:19 PM   #5
Just call me Sean
Just call me Sean's Avatar
Pep Boys has the taillight lenses for $20 each, but I haven't picked them up yet to check them out. Also, for some reason they say for Blazer and Suburban but not pickup, yet they're all the same.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 12-15-2014, 10:04 PM   #6
SCOTI
SCOTI's Avatar
Thanks for the feedback guys.
LMC & Classic Industries were the 2 main suppliers I looked into as well as OER & Cheyenne Pickup Parts. I think Classic & Cheyenne were the only sources that I found all relevant parts for my needs. I couldn't find the side markers on LMC's site. Weird thing is Classic indicates "OE or replacement whichever is preferred" but don't list different p/n's so there no way to designate your desire for original when ordering online.
TX..... I'll check into Certifit. Didn't consider that source.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-15-2014, 10:20 PM   #7
dfrank
dfrank's Avatar
Just checked the book. The gm part nubers are
GM LH G3242
GM RH G3241
These dont have the trim though
Old 12-21-2014, 12:30 PM   #8
Axle
Axle's Avatar
Has anyone had their hands on the Grote rear lenses?
re loose chrome trim, are the aftermarket not like the oem? if they are, pliers and squeeze the retainer tabs tight...
Alex.
Axle is offline   Reply With Quote
Old 12-21-2014, 09:01 PM   #9
Shifty One
Shifty One's Avatar
Alex.
I sell the Grote ones, and have used them on my last 87 (4dr R30), and they fit just fine with no loose retainers. I'll be buying a set tomorrow for my "new" 87 (V20), as well as their side markers.
Old 12-21-2014, 09:32 PM   #10
SCOTI
SCOTI's Avatar
To follow-up..... I purchased all my lenses through board vendor GMC Pauls. Prompt follow-up. Excellent communication about shipping after the sale & they arrived within days. I've had previous dealings w/them & will continue to bring them my business and/or refer them. All pcs indicate Made in USA....
That being said, the lenses lack OE details but should work fine. The trim isn't quite as 'bright' as OE, but very close. The side markers lack the black boarder behind the polished trim but some satin black w/a brush can fix that. The tail-light lenses don't seem to seat as close to the body as the OE units. They don't look bad per say, but the amount they 'poke' out doesn't sit well w/me. I'll go check out the 'Grotes' brand @ my local Advanced to see how well they compare since I know they're close by.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-22-2014, 06:57 PM   #11
Axle
Axle's Avatar
Those little differences may be what keeps them from getting sued by GM for producing a non-authorized reproduction part. Change it a bit and it is simply a replacement part.
Alex.
Old 12-22-2014, 08:17 PM   #12
SCOTI
SCOTI's Avatar
Alex.
Possible, but I don't believe GM made the lenses to begin with??
I pulled the polished trim off an old lense & swapped it over to a new one. Definitely a difference. The new trim is bright alum; the original appears to either be polished more so or chromed. The original trim matches the tailgate insert perimeter edges much better. The aftermarket trim would look fine against no-panel or one that is more brushed vs. polished/chrome.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-14-2015, 07:18 PM   #13
Shifty One
Shifty One's Avatar
Also following up, I put the Grote ones on, and I'm very happy with fit and function.
Old 01-14-2015, 07:47 PM   #14
SCOTI
SCOTI's Avatar
I got different tail light lenses from Autozone. The Advanced had the Grotes line but no fleet tail lenses. Autozone had them & the trim was polished like the OE units so I got them.
I think the units from GMC Pauls would work fine if you don't have tailgate trim directly beside it as the diff was obvious w/my set-up.
On another note, I went to tape off the polished trim on the front/amber side marker lenses to paint the black border that's not there. While taping off the 1st one, the trim easily came off. I checked the 2nd one (just barely picking @ it) & it came off as well. The weird thing is the trim on the rear/red lenses appears to be firmly in place for both sides. So now I have to adhere the trim back on securely.
Not sure what I'm going to use as my bonding agent yet.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-17-2015, 09:39 AM   #15
Axle
Axle's Avatar
Silicone will do the job.
