12-15-2014, 07:51 PM | #1 |
Alignment Spec recommendations
Have a 69 shortbed with a F body subframe. SPC upper arms. Cut springs (not on the uncut bump stops)
Anyone recommend a starting place for alignment specs? |
12-15-2014, 11:07 PM | #2 |
Re: Alignment Spec recommendations
Look up the alignment specs for the year f-body the subframe came from. Start there.
12-15-2014, 11:24 PM | #3 |
As much caster as you can get and .5 negative camber 1/8 toe in
