![]() Join Date: Aug 2013
smooth fire wall
does any one have pictures of their 68 thru 72 c 10 fire wall that's been smoothed out ? am trying to figure out which holes to fill to clean things up.
![]() Join Date: Jul 2010
Re: smooth fire wall
Here is one of our smooth Nsane firewall's!
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
mine....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Moose, that's so much Mo Bettah than a bolt on sheet. Good Job!
motor exploder
Here's my junk pile.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Here is one of mine
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
And another
Thanks guys I really appreciate all the great pics, I fire up the welder first thing tomorrow.
Here is mine...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Maggro. You can smooth the fire wall then make your plan for where you want the Ac lines to exit. I have the green truck that are all coming out straight and the blue one is set up to go in the truck under the front fender on the passenger side where you can't see any of the lines. Both trucks have vintage air and you can spec them out with the fitting locations you desire. You can also buy bulkhead fittings to place them where ever you want and then just run hoses to your under dash location.
